#1 |
Garage conversion subfloors
I am converting a garage into a bedroom. The garage has a concrete floor and is surrounded by block walls. We installed a vapor barrier on the concrete floor then built up the subfloor with conventional 2x6 floor joists. The inspector is telling me, that the subflooring has to be pressure treated. What is the answer to this problem? I don't want to have to remove my entire subfloor.
#2 |
When you say "subflooring", I think plywood that covers the floor joists, but it sounds as though you are referring to your actual floor joists themselves.
How much air space between concrete and non trated framing material? Also, ask the inspector if you can use this paint on preservative... http://www.google.com/products/catal...ed=0CGcQ8wIwAA# |
#3 | |
Garage conversion subfloorsQuote:
#4 |
Octopus,
Thank you for your Rustoleum tip. I don't see any reason we can't apply that and make the sub-floor meet the requirement. I didn't see the sense installing a complete pressure treated sub-floor, but that is what the IBC is calling for, it is section IBC 2304.11.2.4: Sleepers and sills on a concrete or masonry slab that is in direct contact with earth shall be of naturally durable or preservative treated wood. I think the application of the Rustoleum makes it naturally durable, don't you? Thanks again, Chris |
#5 |
sounds like the vapor barrier would be a moisture /slab separation in lieu of paint or pressure treated
The older I get the better I was |
#6 |
I thought it was too. I believed that was all we needed to do for a moisture barrier, but not according to the inspector. He quotes the IBC 2304.11.2.4 referring to sleepers and sills, they must be pressure treated or wood preservative if they are on a concrete slab that is directly in contact with earth. Frustrating.
#7 | |
Framing Contractor
Joe Carola |
#8 |
Joe,
It is standard framing, with perimeter band boards and 2x6x12 spf floor joists between the bandboards. The moisture barrier was installed on the concrete floor first then the floor joists. They may be off the floor 1/2"-1" at places. That is about it though. Chris |
#9 | |
Framing Contractor
Joe Carola |
#10 |
The back of the band boards are bolted into the block walls, but we did not use hangers because the joists are on the moisture barrier on the floor.
Chris The local building inspector has ok'd the floor, he said as long as we installed a moisture barrier we are ok. I hope this is enough for the bank FHA inspector. |
#11 |
This is old news by now, but I have been doing some reading and anyone else who runs into this issue might be interested:
I think the problem came from the inspector applying a commercial code to a residential project - IBC 2304.11.2.4 (commercial code) doesn't have a provision for a vapor barrier exception to the slab on ground condition, whereas IRC R319 (residential coed) does. IRC R319-3: "Sills and sleepers on a concrete or masonry slab that is in direct contact with the ground unless separated from such slab by an impervious moisture barrier." IBC 2304.11.2.4: "Sleepers and sills. Sleepers and sills on a concrete or masonry slab that is in direct contact with earth shall be of naturally durable or preservative-treatedwood." |
| Display Modes | |
| removing rafter ties: garage conversion | neil_9 | Introductions | 0 | 09-29-2010 08:55 PM |
| Garage Conversion | SDEngr | Remodeling | 13 | 06-01-2010 05:11 PM |
| Vacation Home garage conversion | imgarret | Remodeling | 0 | 01-30-2010 09:15 AM |
| Garage conversion | gspro | Building & Construction | 1 | 09-01-2008 04:37 PM |
| Garage Workshop Conversion | Talos4 | General Discussion | 15 | 02-01-2007 09:56 AM |
