Old 08-26-2008, 11:57 AM   #1
Garage Conversion: Loading Bearing Foundation
Post #3 concerning my garage converison. This time, moving onto the foundation.
**At the front of the house.
I want to remove the existing garage door, and leave the existing header (I assume this is load bearing).
For looks, I want the foundation wall to go all the way across. So I want to bring in a mason to install a non-load bearing foundation wall, which will match the existing wall.
Then I want a carpenter to do a 2x4 frame, and install two windows.
**At the back of the house, I want to create a 5' sliding door, where none currently exists. So the mason will have to cut the load bearing foundation. And a carpenter would have to do the framing.
What are the potential problems? What should I look out for?
Thanks again,
Chris
wrldruler is offline   Reply With Quote
Old 08-26-2008, 02:17 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
One thing that comes to mind is your window height will be lower then norm. that's if you raise the garage floor. second the wall will have to be installed on some type of footing (trench) which must be below frost line.if your lucky you can break the floor under the garage door and dig down about 10-12" you might hit the continuing foundation wall. depending on how old the house is. If your lucky you can block from there and up.
Old 08-26-2008, 08:59 PM   #3
Framing Contractor
Thanks again,
Chris
Chris,
Around here in NJ, the foundation footings are the same depth on all walls. Can't imagine why they would do it different and not have your footing where the door is at the same depth as the rest of the walls.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-26-2008, 10:11 PM   #4
buletbob's Avatar
Good point! we do the same here but lower the foundation 12" below the floor height at garage doors and side door locations To cut back on the floor from cracking along the wall. but I have seen older homes 50"s where they stopped at each side of the door locations, straight down to the footing
Garage foundation seaside Building & Construction 3 09-18-2007 09:51 AM
Garage Workshop Conversion Talos4 General Discussion 15 02-01-2007 09:56 AM
Ledger for garage conversion rotorhead115 Flooring 7 01-31-2007 07:11 PM
need to level floor ~ garage conversion gwendda Remodeling 3 03-17-2006 10:35 AM
Garage foundation questions Don-NH Building & Construction 2 04-16-2005 01:03 AM
