Garage Conversion Into Living Space With Bedroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 03:02 PM   #1
garage conversion into living space with bedroom
i own a home that has a two car garage built underneath it.
the garage is split into halves one side is used for storage the other is empty dead space to small for either of our suvs.
The empty space is directly below my teenage twin daughters room. we would like to knock a hole into the floor drop a stairway into that area and create a 2 floor suite for them.
the only issue is that the furnace is built into the side of the garage,and currently isn't fully enclosed. Without calling an inspector, and the city out, and wasting our time and theirs. We want to know would it be ok to convert the garage into living space for them?
brookendarren is offline   Reply With Quote
Old 12-15-2010, 04:40 PM   #2
Pictures would be very helpful.
littlecleo is offline   Reply With Quote
Old 12-15-2010, 05:41 PM   #3
Framing Contractor
Why would you be wasting their time when they are the ones you are supposed to be talking to anyway. Call them on the phone and ask them. They won't just come out and tell you what to do. They will tell you what you need to do over the phone.
Yes, you can, but you have to follow all building codes.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-15-2010, 10:00 PM   #4
Registered User
Rewards Points: 5,520
As Joe said, Check locally for minimum safety.
No openings
from garage to sleeping room-- IRC 309.1
pp.4; http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Gary
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
reclaiming garage space Scott2 Remodeling 3 02-18-2010 07:26 AM
Garage conversion gspro Building & Construction 1 09-01-2008 03:37 PM
closing vents in unused living space scottydel HVAC 1 12-05-2006 01:39 PM
Floor sealing on balcony over living space absorka Building & Construction 3 11-03-2006 06:36 PM
