Garage Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 04:12 PM   #1
Garage Conversion
I'm converting my garage. When I frame the opening I will be attaching the sill to the stepped down apron that the gargae door closed on. It is 1 1/2" down from the garage floor. Seems this would leave the door draginfg the finish floor. Shouldn't I add a second board to the sill to raise it above the garage floor. The floor just inside the door will be tile and transition to carpet. Once I've hung my new door what would be the best way to hide the sill before the siding goes up. I intended to hold the vinyl siding up off of the apron by a small amount. Any ideas would be appreciated.
2dcook is offline   Reply With Quote
Old 01-26-2011, 04:19 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
need pics
tcleve4911 is offline   Reply With Quote
Old 01-26-2011, 05:18 PM   #3
Conversion
I talking about the stepped down area in the picture of the garage floor. In the picture I found online of a finished facade you can see the sill. I want to avoid that and I am looking for suggestions to that end.
Thanks,
David
Old 01-27-2011, 12:27 PM   #4
Rewards Points: 5,336
You don't build the exterior fascade that way. You build it so the threshold is above the concrete. You take into account both the interior and exterior issues and you plan accordingly.
Failure to do so is poor planning.
In the picture above, I would pull the door and raise it up over the concrete lip, taking into account the interior flooring situation.
Ron
Garage conversion 2dcook Building & Construction 2 01-22-2011 12:07 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Garage Conversion SDEngr Remodeling 13 06-01-2010 04:11 PM
Vacation Home garage conversion imgarret Remodeling 0 01-30-2010 08:15 AM
Garage conversion gspro Building & Construction 1 09-01-2008 03:37 PM
