Garage Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 11:27 AM   #1
Garage Conversion
I will be converting my garage to conditioned spaced soon. It currently has a 1-foot-high by 10" wide stem wall/foundation with the exterior walls framed on that(2x4's)....so there is about 5 1/2" of stem wall uncovered by wall plates.
For insulation purposes, would it be best to just frame new walls directly on the existing floor, adjacent to inside face of stem/foundation wall? I just can't think of any other way to do it and still be code-compliant(insulation-wise)....
Thanks,
Brandon
Brown Dog is offline   Reply With Quote
Old 04-18-2010, 01:08 PM   #2
Rewards Points: 1,016
Some areas, mine for one, are very perticular about garage conversions. My city actually has people looking for unpermitted conversions and you will get contacted by the city. I would suggest you ensure you investigate and get any required permits before doing any work.
Old 04-18-2010, 01:22 PM   #3
Yep...I will be getting the entire job inspected.
Old 04-18-2010, 04:23 PM   #4
Pro
Nostco's Avatar
If it's non-load bearing, you can frame new walls in front of the existing foundation wall. If it is going to be load bearing, then you may (may) need to assess the slab and possibly install footings or pads if you're going post and beam.
See why pictures help?
You can also get creative and frame a "step" around the stem of the foundation, thereby giving you continuous insulation along the wall. You won't get a straight wall, but maybe that would work for you (it will definitely give you more room).
Good luck.
Nostco is offline   Reply With Quote
Old 04-18-2010, 04:31 PM   #5
Thought about the "step" idea too. I just was interested in how others, who may have had a similar issue, worked it out. Thanks for the help guys.
Vacation Home garage conversion imgarret Remodeling 0 01-30-2010 09:15 AM
Garage Conversion questions TaazKareem Building & Construction 9 09-24-2008 10:13 AM
Garage conversion gspro Building & Construction 1 09-01-2008 04:37 PM
Garage Conversion: Loading Bearing Foundation wrldruler Building & Construction 3 08-26-2008 10:11 PM
Garage Workshop Conversion Talos4 General DIY Discussions 15 02-01-2007 09:56 AM
