Old 05-19-2005, 12:31 AM   #1
Garage Concrete Slab...HELP?
We are buying a house with a garage. The concrete slab it is sitting on is cracked (would guess about 2" difference in height in spots).
I hope to make the garage a fishroom...housing many aquariums.
The garage sits on the foundation.
What is an ideal way to approach this situation?
I was wondering if I could just pour some concrete on top of cracked concrete?
Jackhammer instead, and apply to inside edge of old concrete?
Trying to lift garage, and jackhammer it all out...and repour?
Just build a new garage, and tear down the old one?
I would guess the garage is aged, but still has structural merit.
I'm just looking at something cheap and effective.
Any information would be appreciated.
Aqua-Man is offline   Reply With Quote
Old 05-19-2005, 10:55 AM   #2
See if I understand what you have... Your garage walls are built ontop of foundation walls and the floor is poured inside these foundation walls? If that's the case, then I would jackhammer out the old floor and prep the grade for a new floor.
Your floor probably failed due to settling of what's under the concrete, the backfilling when it was built. In cold climates, if the overhead door is left open for long periods of time, the floor can freeze causing heeving(sp) and bust it up.
Mike772 is offline   Reply With Quote
Old 06-17-2005, 02:11 PM   #3
I now live in Florida where the weather is constant and we don't have much concrete or asphault cracking. I didn't realize how bad the cold can be on these surfaces until I went back up north. Good suggestion to keep your garage closed for the northerners...
David Meier
Meier's Enterprises Inc. [Pressure Washing]
Email: d a v i d @ m e i e r s e n t e r p r i s e s . c o m
Daily Tool & Computer Deals http://www.DailyTool.com
meiersenterprises is offline   Reply With Quote
More On This Topic
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
When undertaking a home improvement project, you need to know how much concrete you will need and what kind is best for your project. Determining the right amount and kind of concrete you need will save you money and trouble in the long run. Read on to... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking for cracks around the foundation. When winterizing my house, the first thing I like to do is take a look around the foundation and see if any cracks have formed. Now... Read More »
Sawcutting concrete can prevent driveway and walkways from cracking while allowing you to add various designs, such as diamonds and stars. You can use this technique to maintain the quality of your concrete for years. Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The next step in the process was to have the slab poured in the base here and actually I have that as a term key job because it was about 20 yards of concrete and that is more then... Read More »
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
