Garage On Cement Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 08:01 PM   #1
garage on cement slab
I am building a garage on a 6 inch thick cement slab. As such it rises about 3 inches above the ground. I'm in an area where it gets extremely cold. Is there anything I have to do to ensure the frost does not get under it and heave it? Thanks.
beech is offline   Reply With Quote
Old 08-08-2009, 08:29 PM   #2
Rewards Points: 1,016
How deep is your frost line?
You need some type of footing in addition to the slab itself -
http://www.concretenetwork.com/concrete/foundations.htm
And of going with a monolithic slab, also think about how much of the slab extends out of the ground - you don't want your siding down near or against the ground. And your site is probably not level, it will have some grade you have to account for.
Old 08-08-2009, 08:59 PM   #3
Registered User
Rewards Points: 4,924
As we don't know your location...... http://www.soundfootings.com/pdf/US_...t_DepthAVG.pdf
6" above grade per code: http://www.codecheck.com/cc/images/CC5thEdSample.pdf The first three pages.
Gravel: http://rockproducts.com/mag/rock_agg...prevent_frost/
Unheated buildings: http://www.oikos.com/esb/43/foundations.html
Be safe, G
Old 08-13-2009, 12:46 AM   #4
I wouldnt worry about it on a floating slab..I live in Wisconsin and have never poured footings for a garage.. not even the 40*80 timber frame barn we put up..and that slab stayed bare till the next summer.
ebstein is offline   Reply With Quote
Old 10-17-2010, 09:55 PM   #5
Here in Northern Ont. Canada, it gets cold. I have never yet seen anyone pour footing down below the frost line for a garage. they are all built as a floating slab on grade. Use lots of re-bar and min. 32mpa concrete. make sure you have good drainage to take any water away from the building.
bushmoose is offline   Reply With Quote
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 11:24 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
upright posts in a wet cement slab shellgirl74 Building & Construction 7 03-19-2009 12:06 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
