Garage Ceiling Storage With Open Web Joist System - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 09:33 AM   #1
Garage ceiling storage with Open Web joist system
My garage is barely big enough to fit our cars but it does have nine foot ceilings. Thus, I purchased some Hyloft 45x60 storage system that connect to the ceiling joists.
Since my home is newer the builder used an "open web" system of joists where it is basically 2x4 lumber on the top and bottom with 2x4 angled supports and braces. Supposedly these engineered systems are stronger and cheaper since you do not have to bore a hole in the traditional 2x12 to accomodate wiring and hvac piping.
However, my initial attempts at research I found a load chart that typically these systems can support 65 lbs per sq ft. But that load is typically 50-10-5 where the 5 represents "low dead load" which just so happens to be where I am attaching the storage systems to the ceiling.
I contacted Hyloft and they indicated that this should not be a problem, but I would prefer to have a 2nd opinion to ensure that I am not going to have things fall on my head including the master bedroom that sits above the garage.
If it helps, the garage is just under 20x20 feet and has no support pole in the middle. Everything is connecting to the side of the house and interior middle on back and left sides.
BillyDIY is offline   Reply With Quote
Old 07-29-2010, 12:30 AM   #2
Registered User
Rewards Points: 4,914
Page C-6, #28- 30&40#: http://books.google.com/books?id=k-D...page&q&f=false
Be safe, Gary
880lb hoist from garage ceiling etriad Building & Construction 15 02-26-2011 05:18 PM
cracked ceiling joist near garage door support mikebull Building & Construction 1 07-06-2010 06:20 PM
garage door open light deck hand Electrical 3 01-22-2008 09:29 AM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 11:50 PM
ceiling joist this old house Building & Construction 2 03-23-2006 10:00 AM
