Garage Ceiling Shelving Building Know How - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 05:41 PM   #1
Rewards Points: 672
I am wanting to build some shelving from my two car garage ceiling that I can store leftover lumber and such. Does anyone have any suggestions, links, plans, pics on an easy, cost effective plan for me to build? Thanks.
kennykenny is offline   Reply With Quote
Old 06-26-2013, 06:14 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by kennykenny View Post
wanting to build some shelving (suspended) from my two car garage ceiling...
It starts with how the rafters (more likely truss chords) are built...
and whether the dead load can be supported from them ... or whether something needs to be done to reinforce them first.
Beyond that's it's just a question of how pretty you want to make it.
Old 06-26-2013, 06:41 PM   #3
Rewards Points: 13,750
Post some pictures of what you have please.
Old 06-26-2013, 10:26 PM   #4
Rewards Points: 672
I'll get some pics sent. My garage has a finished ceiling. No exposed rafters.
Old 06-27-2013, 09:25 AM   #5
MarginallyQualified
Then be sure to climb up above for the pictures and measurements.
Old 06-28-2013, 09:29 PM   #6
Rewards Points: 672
Attached are some pics of my garage. As I hope that the pics show to you, the useable ceiling storage area is broken up into two areas separated by a middle dropdown section. The front section(the area farthest from the garage door) is approx. 103 x 240 and the area on the side of the garage door is approx. 134 x 240 with the garage door opener rail separating the section almost exactly in the middle.
I hope that this allows you to give you provide me with necessary information. Thanks!
Garage Ceiling Shelving Building Know How-garage.jpg   Garage Ceiling Shelving Building Know How-garage1.jpg   Garage Ceiling Shelving Building Know How-garage2.jpg   Garage Ceiling Shelving Building Know How-garage3.jpg   Garage Ceiling Shelving Building Know How-garage4.jpg
Old 06-28-2013, 09:55 PM   #7
Is there a finished room above the garage?
If not we needed picture from above the ceiling not below.
Old 06-28-2013, 10:23 PM   #8
Rewards Points: 672
Yes there is a finished room, no access, above the garage. Thanks!
Old 06-28-2013, 10:36 PM   #9
MarginallyQualified
Ask around among your neighbors for who has either had reason to open up their garage ceiling or who didn't opt for the sheetrock ... and hope that tells enough to base a plan on.
In short... if you want to suspend real weight (more than a bicycle or a pair of ski's) you will need to add lumber *into* the framing. Adding something above the framing would be even better but that ship has sailed.
hth
Old 06-29-2013, 08:47 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
along with hanging from the ceiling how about some type of angled 45 degree brace that takes the front portion of the shelf weight back to the wall and not just hang the whole system off of the ceiling. with the angled brace it is a combination of the two...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
MTN REMODEL LLC (06-29-2013)
HELP building garage heating system ridinloudprod HVAC 17 01-14-2013 09:07 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 07:16 PM
garage ceiling mferguson0414 Carpentry 2 01-13-2009 10:24 PM
