Garage Ceiling Reinforcement For Storage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2011, 03:10 PM   #1
Garage ceiling reinforcement for storage
I am in California and currently have a detached gargage measuring 17'X20' that I would like to modify to add attic space for storage. The garage was built with the house in the 1950's and currently has no ceiling structure. It just has a couple of long 2x4's along the 17' stretch and a few 1x6's(laying flat) running diagonally. Other than that I can look right up at the roof rafters which measure 16" on center.
I really need to create some out of the way storage space, and was thinking about building some attic or storage space above. Here are some specs:
Total garage dims - 17'wide X 20'deep
The roof is 4 sided with the longest roof rafter a 5' from ridge to wall on the 17'width side.
Max inside roof height at the ridge 12'10"
I know the spans are somewhat long so I was thinking I would probably need to run a beam across the center of the 17' section, then tieing 2x's into that 16" on center using Simpson joist hangers. I plan on storing boxes with christmas stuff and the like. I may even need to crawl up there on occasion (I am 250lbs) Here are my questions:
Is this a good idea?
What size and type of beam would suffice?
What size 2x's would be needed to tie into the beam?
Are there better ways of doing this?
I am in So Cal so no snow problems here.
Thank you all greatly in advace. This were definately get the wifey off my back. For a while anyways
Mike
Mike274 is offline   Reply With Quote
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 03:10 AM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 02:46 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 01:40 AM
Garage ceiling joist support mountainmike Building & Construction 11 02-28-2009 08:16 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 03:46 PM
