Garage Ceiling Joist End Cut - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 11:12 AM   #1
Question
garage ceiling joist end cut
which end cut should i use for the ceiling joist 2x8's running 19'. There isn't much space on the top plate.
garage ceiling joist end cut-photo-1-.jpg   garage ceiling joist end cut-photo-2-.jpg
betto825 is offline   Reply With Quote
Old 05-01-2013, 11:27 AM   #2
Old School
Willie T's Avatar
Do you have a reason for wanting to cut the bird's mouth notch in them? It's unnecessary, and will, effectively, lower the load bearing limit... but not all that much.
BTW... 2x8's running a full 19'? You checked that out on a span chart? I wouldn't plan on storing anything up there.
Willie T
Old 05-01-2013, 12:30 PM   #3
Thanks for the reply. No particular reason at all, just looking for the more stable method. I was told that 2x8's SEL STR DF S4S at 16" on center would span 19'. 5" and be able to hold drywall and insulation.
Old 05-01-2013, 12:35 PM   #4
Old School
Willie T's Avatar
I haven't looked it up, but even at 12" OC, I'm pretty sure 2"x8"s (ceiling only, no floor above nor storage) can only span about 18'-9". And at 16" OC, 2"x8"s are limited to just a hair over 16'.
Of course, my memory could be off a little (I'm old), so go look it up for yourself.
No big deal. It probably only means the ceiling will sag... probably not break.
Willie T
Old 05-01-2013, 04:09 PM   #5
Rewards Points: 502
Notching the beam at the end won't increase the tendency to sag, and also won't affect the bending stress in the beam.
All notching or chamfering does is to increase the shear stress at the bearing but in domestic situations, and particularly with ceilings, the loads are so low that shear is very rarely an issue.
There is little diference in the two methods, but personally I would be inclined to go with the top one. Occasionally the abrupt change in section that you have in the bottom pic can occur in a line of weakness in the grain and cause localised splitting, but that's probably splitting hairs!
tony.g is offline   Reply With Quote
Old 05-01-2013, 05:34 PM   #6
joed's Avatar
Rewards Points: 12,362
I would use no notch method in #1. The square notch looks like a potential fracture point to me.
One advantage is that it leaves the top plate to use for drywall attachment of the walls.
The Following User Says Thank You to joed For This Useful Post:
Larryh86GT (05-01-2013)
Old 05-01-2013, 10:47 PM   #7
Rewards Points: 81
thanks for the reply. No particular reason at all, just looking for the more stable method. I was told that 2x8's sel str df s4s at 16" on center would span 19'. 5" and be able to hold drywall and insulation.
s4s???
one cut is offline   Reply With Quote
Old 05-01-2013, 10:59 PM   #8
Maryland
Originally Posted by one cut
s4s???
Surfaced 4 Sides
Pittsville is offline   Reply With Quote
Old 05-02-2013, 09:14 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
no notch, you want the bearing point to be across the bottom of the joist not up 1 1/2" into the joist. whatever notch you cut into it will then qualify as the actual width of the joist from the bearing point of the notch to the top of the joist, so a 1 1/2" notch would be like adding a 2 x 4" joist up there because the bearing point is 4" from the top of the joist.
hand drive is offline   Reply With Quote
Old 05-02-2013, 09:48 AM   #10
Roofmaster
Rewards Points: 2,172
You cannot span 19 feet with a 2 x 8. Well, I guess you can if you want, but it is going to deflect pretty badly.
Old 05-02-2013, 09:56 AM   #11
AHH, SPANS!!!
that is an issue... probably best to double up some of the joists and add blocking between them mid span to add some re enforcement to the span...
Old 05-02-2013, 10:56 AM   #12
GBrackins's Avatar
Rewards Points: 2,108
notching will reduce ceiling height. here is a link to the 2009 International Residential Code span tables for ceiling joists. pick out which one applies (storage in attic or not) and it will give you the allowable spans. http://publicecodes.cyberregs.com/ic...9_8_par027.htm
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-02-2013, 12:12 PM   #13
joed's Avatar
Where do you get 20 foot 2x8 anyway? 16 are the longest you get here without special order and high expense.
Old 05-02-2013, 01:05 PM   #14
Joed, The local lumber yard here has them up to 32'. The 20' are $17.00
hand drive, Yes I was already planning on adding blocking.
GBrackins and jagans, if I am reading the chart correctly Douglas fir Larch SS without storage can span up to 24' 8" and with limited storage 19' 7" all at 16" on center
I am just gonna go with the 2nd method and avoid loosing ceiling height. You guys are great and your feedback is very well appreciated. Now to figure out how the heck am I gonna get those joist up there
Old 05-02-2013, 07:50 PM   #15
AHH, SPANS!!!
you could probably even split some 16 foot joists on those 19' ones and add 2' finish out pieces to add somewhat of a double to cover the span. just nail them really good together to make the double count.
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 02:46 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
