Garage Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 03:14 PM   #1
Garage ceiling
Is it possible to hang a storage rack from the garage ceiling? I can't find solid studs to attach my hanging brackets. The studs appear to be made of thin metal and I cant tighten the lag screws.
arpeegee is offline   Reply With Quote
Old 08-28-2011, 03:43 PM   #2
Experienced
Jackofall1's Avatar
Hello and welcome arpeegee, to the best darn DIY'r site on the web.
Yes you can connect a hanging rack to the ceiling joist, the question then has to be asked, how much weight are you going to load these storage racks with.
That being said, if you are going to connect to the ceiling then you should consider dropping a leg down to the floor at each joist connection, to ensure you don't overload the joist.
Personally I would be looking at heavy duty free standing shelves, then there is no question for structural integrity.
Mark
Old 08-29-2011, 12:05 AM   #3
dpach's Avatar
Just to give you an idea of what can be done.
I've got 10 foot walls in my garage that was designed that way so I could hang these shelves around the perimeter.
The back rests on ledgers attached to the wall studs, and the fronts hang from top plates spread over 2 ceiling rafters to spread the load.
Been there now for 6 yrs and no movement whatsoever.
dpach is offline   Reply With Quote
Old 08-29-2011, 12:12 AM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
dpach,
Nice tool organization.
picflight is offline   Reply With Quote
Old 08-29-2011, 12:50 AM   #5
dpach's Avatar
Originally Posted by picflight View Post
dpach,
Yeah, I'm kind of a nut when it comes to organizing things. Everthing has its place....only because I figure I'll end up living in this garage some day (lol -- wife gets the house).
Vapor barrier in garage ceiling? titaniumring Drywall & Plaster 14 10-20-2011 08:14 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 12:40 AM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 02:46 PM
