Old 04-27-2008, 10:35 AM   #1
Garage Cathedral Ceiling Insulation
Hello everyone, yes I am a Newbie so thank you for your patience.
I am trying to insulate my cathedral ceilinged garage in order to make it more comfortable to work in here in Southern California. Here are the facts: 2 x 4 construction, 16" on center, no soffit or ridge vents. I had intended to apply Reflectix to the underside of the roof and then fill with basic fiberglass insulation and top off with drywall. However, because of the 2 x 4 construction, there is not enough room for air flow except that I have no soffit or ridge vents to even allow for air flow. So I thought I might buy a Whirlybird to suck out hot air, but these seem to only be for enclosed attics. I also am concerned that my idea may invite moisture to gather underneath the drywall and then subsequently force me to redo everything.
Pic: http://www.benjamineric.com/images/roof/IMG_8296.jpg
Any help is greatly appreciated!
Thank you-
Benjamin
onecanoe is offline   Reply With Quote
Old 05-01-2008, 04:28 PM   #2
Advice worth 2 cents!
Be careful dude, check with the roofing folks (especially Ed the Roofer) before you do anything. Asphalt shingles need to have a ventilated roof and that can be tricky in your case.
GET AN EXPERTS ADVICE!
- pete
---pete
HandyPete is offline   Reply With Quote
Newbie Insulation Question: Cathedral Ceiling Battman328 Building & Construction 5 01-24-2008 06:37 PM
Insulation of a Vaulted (Cathedral) Ceiling cbeingessner Building & Construction 2 01-14-2008 12:19 AM
Cathedral ceiling without sofit vent on one side ChrisO Roofing 3 01-31-2007 11:51 AM
Cathedral ceiling ventilation dpreznik Roofing 2 10-31-2006 11:18 AM
Cathedral ceiling insulation Unregistered Building & Construction 2 09-17-2005 01:21 AM
