Garage Cabinets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2007, 03:13 PM   #1
Garage Cabinets
I plan on building cabinets in my garage. They will be 108" high by 93" wide by 16" deep with doors. Does anyone have suggestions for construction of the cabinets and material for the doors? I do not want interior cabinet quality but something that will be sturdy and still look good.
tband is offline   Reply With Quote
Old 09-14-2007, 04:31 PM   #2
DeeTee's Avatar
Cool
One Way
One idea would be to use 3/4" interior grade plywood. Put it together with screws and maybe pre-drill any face screw locations maybe even countersunk. You could stain or paint. I think I'd paint. If I had some shelves that were going to have heavy things on them I might strengthen them using some 2x2s on their undersides. I think I'd use 1/2" for the doors.
___________________________________________
Precision is always relative to the surrounding degree of perfection.
News Views Tips Commentary Downloads at the Construction Informer
DeeTee is offline   Reply With Quote
Old 09-15-2007, 01:21 PM   #3
Darylh's Avatar
I would build 4 cabinets at 23-1/4" wide x the height and width. I would use real 3/4" plywood glued and screwed. You will want 2 fixed shelves to stop any bowing as well as a solid back like 1/4" sheeting to keep them square and stable. The doors can be plywood also Good One Side or laminated pine ( I have Pine for my 7" cabinets. You will want to make 2 doors for each cabinet.
Here is a quick look http://www.geocities.com/dmhworkshop/introductionpage1
Darylh is offline   Reply With Quote
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
