Garage Build - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 10:30 AM   #1
waterman1971's Avatar
Rewards Points: 154
Garage build
What would yall recommend for the supporting beams marked in red? The beams span 20'. I was thinking double 2x12 with plywood. Any other ideas? Posts are on 6' centers.
waterman1971 is offline   Reply With Quote
Old 05-01-2010, 11:21 AM   #2
Civil Engineer
Rewards Points: 4,942
The beams in question need to support half the garage roof live load, plus dead load of framing, plus wind load and seismic load if applicable. Your local code should tell you the required loading. You can also get the required information from your local code enforcement official (you are pulling a permit, right?).
You should also look at the requirements for attachment of the beam to the support posts. And while you are at it, you should review the requirements for embedment of the support posts, and minimum sizing of the support posts. Assuming you have not done so already.
By the way, nice drawing.
Old 05-01-2010, 11:25 AM   #3
Rewards Points: 1,910
If that's all the structure a good wind will topple that garage right over. Your going to need lateral bracing. Is the full 20' end goiing to be open?
Why beams every 6'? Good trusses will span the 24' without intermediate beams. If you'll stick frame and/or put load in the attic or occupy it then you might need 1 or 2 intermediate beams depending on the ceiling joist size.
Beam size really needs to be calculated by an engineer or use of prescriptive tables depending on location and construction details.
Old 05-01-2010, 11:34 AM   #4
Rewards Points: 154
The structure is attached on 1 side. I want the beams so i can better utilize the space above. I created the "trusses" as a component in the rendering. They are for reference purposes only.Traditional plywood decking and composition roofing on top. Plywood sheathing on the sides may increase lateral stability. Thanks for the help guys.
want to build corner shelf for 27" tv in garage bowanna03 General DIY Discussions 2 07-08-2009 06:09 AM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Challenge: Build a wall in front of Garage door pink toolbelt Building & Construction 4 11-12-2008 02:19 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 09:47 AM
