Garage Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 08:23 PM   #1
beginner50's Avatar
I was just wanting to know if I had a 12' 22x21 basement dug out with cement flooring and walls can they still put a garage floor on top of that?? Plan on making the top level basically a shop/garage with the basement being a man cave/storm shelter. Sorry probably a stupid question but didn't know for sure. Also anyone got an idea on the price I live in Kansas country house.
beginner50 is offline   Reply With Quote
Old 08-12-2013, 08:41 PM   #2
Rewards Points: 944
Yes, you can do this. You can have a concrete floor on top.
This can be either formed up and poured, pre-formed panels can be set in place and then poured atop, or you can have a reinforced styrofoam system put in and poured on, with re-rod added.
The third option is probably your best choice, because there will be no condensation.
cleveman is offline   Reply With Quote
Old 08-12-2013, 08:46 PM   #3
beginner50's Avatar
Any clue on price to have a company do it??
Old 08-12-2013, 09:20 PM   #4
Rewards Points: 944
For some reason, the figure of $12/square foot for the ICF system sticks in my head.
So you're looking at $7,000 for a 24x24 garage, plus the cost of the footings and walls, plus excavation.
Lots of attached basements are built where the floor has to be filled with sand, rock, etc. So the question is, is it worth it to pay more for the floor and save a bit on fill, and have the space below?
With the 24x24 example, you can get 576 square feet of basement for $7,000, or $12/square foot, plus the additional cost of the full height basement walls, more excavation, etc.
This isn't finished space yet by any means, but you can't get much for $12/square foot.
The other consideration is the displacement of earth. If you can use the fill somewhere, you are creating it by digging a hole.
Old 08-12-2013, 09:25 PM   #5
Framing Contractor
Rewards Points: 116
We just framed a new home that had a garage like this. It had steel beams about 3' apart, with steel sheeting welded on top of that. probably 5 grand in steel for a two car garage, plus the cost of the welding.
sixeightten is offline   Reply With Quote
Old 08-12-2013, 09:35 PM   #6
beginner50's Avatar
Just from the quotes I have recieved for my area to do the top garage floor is around $1,800. Is the dug out basement and concrete that much more??
Old 08-13-2013, 01:15 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Thread closed
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-13-2013, 09:37 PM   #8
An old Tradesmen
Rewards Points: 6,596
Thread cleaned up, and reopened.
The Following User Says Thank You to beenthere For This Useful Post:
BigJim (08-13-2013)
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Running conduit from basement to the standalone garage sheslostcontrol Electrical 10 10-23-2010 01:22 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
