Garage With A Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 02:21 PM   #1
Rewards Points: 264
Garage with a basement
How possible / practical is it to put a basement under your garage? Obviously, you'll have the extra weight of cars and have to support a concrete floor from below (unless you went with steel floor?)
I can see why no one really has one - just seems like it might be cool.
tibberous is offline   Reply With Quote
Old 01-24-2012, 02:30 PM   #2
Retired carpenter
Because most people are not millionaires. Being a millionaire would be cool also.
abracaboom is offline   Reply With Quote
Old 01-24-2012, 02:46 PM   #3
Rewards Points: 150
Both possible and practical. I know a guy who did it and its like a secret man cave. You have to go through a bookcase to get in there. He has a free flowing keg and bar, with pool table, big screen etc. It can be done for sure. He used I think open web steel joists and concrete decking to get it done.
psilva8 is offline   Reply With Quote
Old 01-24-2012, 03:33 PM   #4
I ask the impossible!
Rewards Points: 640
Well, really if you look at what holds up a car on a 4 post lift, then of course it's within the realm of possibility. It's extra expense and complexity, and it wouldn't be done because how often is the square footage at such a premium that the living space achieved couldn't just go somewhere that the structural complexity isn't required.
Personally, I've thought if I was building a detatched garage again I'd go for a service pit.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 01-24-2012, 03:42 PM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
My friend's parents built a house about 2007-2008 with a 2 story garage. The front of the house has garage access that would be upstairs. A driveway goes around behind the house and down a hill with more garage doors on the rear of the house for the lower garage. It's pretty damn awesome, if you ask me.
Here's an aerial shot to see what I'm talking about:
hyunelan2 is offline   Reply With Quote
Old 01-24-2012, 03:58 PM   #6
Rewards Points: 2,210
Worked on a basic 70's bungalow that had it. Sop below the garage.
Used 2x10 joist 12"oc, had a metal pan made for the floor with a drain in it.
We converted the once garage to living room, entry, bathroom.
mae-ling is offline   Reply With Quote
Old 01-24-2012, 04:45 PM   #7
In a little over my head
Rewards Points: 706
One concern (besides the obvious). Fuel vapors are heavier than air. Your basement could easily become smelly/dangerous/explosive. That's one reason automobile service pits aren't as popular as before.
ratherbefishing is offline   Reply With Quote
Old 01-24-2012, 05:22 PM   #8
concretemasonry's Avatar
Rewards Points: 2,578
Depending on you site, using the area under a garage can be a valuable and economical space.
The obvious is for storage and a utility area where you can drive in a tractor, protect it, work on it and keep accessories and other exterior tools.
To use it as a real livable space requires more planning, access, fire requirements and construction details that cost more.
Dick
concretemasonry is offline   Reply With Quote
Old 01-24-2012, 05:44 PM   #9
Rewards Points: 119
It is very common around here. They use pre stressed concrete then pour a cap over that. The rooms are normally storage/safe rooms.
KStatefan is offline   Reply With Quote
Old 01-24-2012, 05:52 PM   #10
Framing Contractor
I worked on a house that had one with two bedrooms underneath. The floor wad concrete and steel. Can be done no problem. Same way as parking garages are done. Like anything else...had to be designed by an engineer.
Joe Carola
Joe Carola is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Running conduit from basement to the standalone garage sheslostcontrol Electrical 10 10-23-2010 01:22 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
