Old 03-20-2013, 12:20 AM   #1
Garage attic storage and weight issues...
So I have a garage with king post trusses. Trusses span about 18-20 feet and they are 24 inches apart. The design is the first one at the top of this image http://images.search.yahoo.com/image...cjb3&fr=opera2
The upper chords are 2x6, the bottom chords and post are 2x4. I plan to put 3/4 osb board for storage. And the peak is probably 5 feet or so. Does anyone think this will be a problem? I don't plan on anything really heavy but the osb must weigh 60-70 pounds a piece and I weigh 250. So I don't want to over load the thing if I'm up there and the stuff is up there. Won't be too much large plastic bins full of old clothes that kind of thing. No insulation and it is supported the walls themselves as the garage has no drywall, just typical 2x4 framing. It was built in 1980....
Help please????
themps is offline   Reply With Quote
Old 03-20-2013, 07:27 AM   #2
It's not designed for storage. If it was the bottom cord would have been wider.
Adding full length 2 X 8's joist would be the way I would go.
Storage in attic pete0403 Building & Construction 4 12-09-2011 06:32 PM
decking an unfinished garage attic? heli0s Building & Construction 8 11-01-2011 08:52 PM
Supporting Garage ceilings joists above garage for supporting storage weight. glexguy Building & Construction 1 03-10-2011 02:12 PM
attic storage storageseeker Building & Construction 2 01-29-2009 09:02 AM
Attic storage - construction type? rt4me Building & Construction 4 01-01-2009 05:33 PM
