Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 10:04 AM   #1
Rewards Points: 49
garage
What sequence of numbers do you use to square a 48x32 building. I know 12L x 16W = 20. Just not sure how you do a 48x32 Would appreciate your help. Thank you
worker903 is offline   Reply With Quote
Old 03-12-2013, 10:05 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
Square with respect to what? The floor plan? The concrete? The walls?
brockmiera is offline   Reply With Quote
Old 03-12-2013, 11:18 AM   #3
retired union carpenter
Send a message via Yahoo to coupe
any multiple of (3-4-5) will give your square. in your case I'd go (18-24=30)
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-12-2013, 11:23 AM   #4
brockmiera's Avatar
Must be a pole barn since the width and length are backwards. If you are looking for a 3/4/5 rule (hypotenuse of a right triangle) go with 30/40/50 that will get you the closest.
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
