Gaps In Brick Around House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 09:55 PM   #1
gaps in brick around house
Well, we moved into a house about 2 years ago and looking around the bottom layer of bricks, it appears that the mortar is gone from about every third brick. Is this normal? or should I fill them back in.
Jware is offline   Reply With Quote
Old 06-22-2008, 10:10 PM   #2
concretemasonry's Avatar
Rewards Points: 2,650
What you see are "weeps" that are built into a brick veneer wall. The purpose is to provide an exit from any moisture (leakage, comdensation, etc.). You may also see some similar gaps at the top of the wall or hidden by a soffit. They also provide pressure equaliastion so there is not exterior pressure to force moistuure into your home. - The wind can blow, but it does not drive water into your home.
I would be more concerned if I did not find them. They are frequently omitted by poor masonry contractors.
concretemasonry is online now   Reply With Quote
Old 06-23-2008, 02:13 AM   #3
Rewards Points: 2,906
Previous poster is bang on. They allow any water inside the wall to drain out from behind the brick so that the brickwork stays dry.
ConcreteMasonary: I have brick veneered concrete block walls on my building. There are no weep holes at the bottom of the brick wythe at all, and I get efflorescence on my exterior brickwork every spring, especially near the top of the building where warm moist air accumulates. I believe that the efflorescence is from the melting frost that forms inside the wall over the winter.
What do you think of the idea of adding weep holes at the bottom of the wall, and the same 30 feet up at the top of the wall, and using the unavoidable heat loss from the building in winter to drive a convective air current between the brick and block wythes to evaporate any frost that forms in that cavity over the winter. Kinda like roof ventilation, only "wall ventilation".
It's not an intentional curtain wall. It's an "American bond" brick wall where every 2nd block is a 3/4 block and every 6th brick row is a row of headers to tie the two wythes together.
Would there be enough of a gap between the two wythes for this scheme to work reasonably well?
Nestor_Kelebay is offline   Reply With Quote
Addition to a veneer brick house DUNN-IT Building & Construction 4 03-19-2008 08:14 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
Brick a house 3DPiper Building & Construction 2 03-28-2007 03:14 PM
Power Washing Brick House bobo Building & Construction 3 09-24-2006 05:53 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
