Are Gaps Absolutely Necessary On Decking? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 10:17 AM   #16
KemoSabe
loneframer's Avatar
Originally Posted by Grizzlybare View Post
Next question.
As I come to the end of the deck, I am faced with many options as far as length of boards. As the deck is some 40' long, I started with a layout pattern of
4'
12'
8'
16'
4'
12'
8'
16
I have an angle corner on the end that makes the deck boards all dif lengths and some will be very short. Is 48"' the shortest board length I should have, 32"?
I try to avoid anything shorter than will span 3 joists. This may vary depending on whether the last bay is a full increment. It could be as short as 3'.
As for the drilling template, hats off.
All the hidden fastener systems I've tried are very time consuming as compared to face nailing or screwing. It depends on how much it bothers you to face fasten, whether it's worth the effort or not.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
thomasjmarino (06-26-2011)
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
Decking Michael Avram Building & Construction 2 05-26-2008 07:24 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
