Old 04-01-2009, 04:36 PM   #1
gap in new drywall install
I just finished drywalling a room. One of my sheets that goes up against the ceiling has a gap. I'm guessing the ceiling is sloped, coz the drywall is square - one side is snug, then about midway accross a gap starts, and gets wider as it goes along - by the end of the drywall it's probably about 1/2 wide. What's the past way to securely fill this? It's too narrow and angled to cut a strip of drywall for - do i just pack some mud in there and let it dry?
mmhendrie is offline   Reply With Quote
Old 04-01-2009, 07:30 PM   #2
Remodeling Contractor
You cut the drywall so it fits. Scribe it to the ceiling, unscrew it and move it up. That is the right way. But you can use hot mud.. (mixed from a bag) which dries harder and will fill this area.
Old 04-01-2009, 11:36 PM   #3
If you are going to fill it, fill with some 5 Min or 20 Min. mud. Using regular drywall compound will take forever to dry.
Mop in Hand is offline   Reply With Quote
Old 04-02-2009, 08:55 AM   #4
They're all fixer-uppers
J187's Avatar
I agree with the above information, however, I urge you to take it down and cut it right. Sounds like you are just starting out with home improvement... take the opportunity to forge some good habbits now.
J187 is offline   Reply With Quote
Old 04-02-2009, 02:08 PM   #5
Drywall contractor
Yes to all of the above....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall install on ceiling buckbob Drywall & Plaster 9 01-25-2009 07:27 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
