Gap Between Drywall At Edge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 08:32 PM   #1
gap between drywall at edge
Hey, Friends.
I have a few gaps in the ceiling at the edge between some drywall and hardibacker. Should I fill this with just drywall mud or something like caulk? Put in underneath the seam tape?
See picture as an example.
RedBear is offline   Reply With Quote
Old 05-03-2011, 09:37 PM   #2
Stay-at-home GC
Drywall mud and tape will be fine
You may want to trim away the paper and remove the cracked sections of green board. Run new screws where the board is not broken.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
RedBear (05-03-2011)
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Repair drywall paper before laying tile? amybeth25 Remodeling 4 08-29-2010 05:49 PM
painting new drywall in bathroom LittleBrownDog Drywall & Plaster 8 08-18-2009 06:53 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
