Gap Between Bathtub Surround And Sheetrock On Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 03:18 PM   #1
Gap between bathtub surround and sheetrock on wall
I set out to re-caulk the 90 degree joint between the walls and the top lip of my fiberglass shower enclosure, but it has turned into a project now. When I cut off the old caulking, it pulled out a bunch of old joint compound or something that had been used to fill gaps between the wall and tub surround. So I now have a 3/4" horizontal gap that runs all the way around the top of the shower. The sheetrock was obviously stopped short of the top of the shower on purpose, so what do I do to fill the gap in?
Beerad77 is offline   Reply With Quote
Old 01-01-2012, 03:21 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Do what was done before. That's a typical installation. Use joint compound for the repairs. Then repaint, then caulk.
XXX
Old 01-01-2012, 10:10 PM   #3
Rewards Points: 2,212
The tubs I have seen and worked around required a gap, which was covered by tile or trim, then a small gap and caulked to the tub.
mae-ling is offline   Reply With Quote
Old 01-02-2012, 11:24 PM   #4
Registered User
Rewards Points: 5,498
"When I cut off the old caulking, it pulled out a bunch of old joint compound"------ it was or something-bagged, setting-type compound, not boxed (air dry). Use paper or mesh tape, paper is stronger against movement. Final couple coats with all-purpose joint compound (boxed, slightly thinned). Caulk the final narrow joint as said.
And, welcome to the forums!
Gary
tiling tub surround grib29 Tiling, ceramics, marble 2 07-11-2011 10:54 AM
Need to add shower to existing bathtub Tmack_5_0 Plumbing 4 04-05-2011 11:08 AM
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Surround Bath/Shower finishing JackVa1 Kitchen & Bath Remodeling 2 08-06-2009 07:37 PM
Behind The Wall (Sheetrock) Surround Sound justme Home Theater 7 03-12-2008 07:14 PM
