Gap Behind Brick Moulding Around New Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 03:11 PM   #1
Rewards Points: 101
Gap behind brick moulding around new door
I am looking for suggestions. I added a back door to my basement. The lower half of the wall is block. There is a gap of 1/2"-3/4" between the brick moulding and the face of the block. What would be a good way to fill the gap, keep in mind the exterior surface of the block is a decorative uneven surface rather than flat.
wvphysics is offline   Reply With Quote
Old 10-17-2010, 03:32 PM   #2
Rewards Points: 5,336
I would have leveled the area before the door went in and added a wood piece to continue the upper plane down to the floor.
Now you're limited to filling in the area with a 1/2" piece of wood and filling the gap with backing rod and caulk.
Ron
Old 10-17-2010, 03:36 PM   #3
Rewards Points: 101
The issue is that the boarding against the upper framework is not flush with te block, the house was just built that way. So it came to a few decisions of practicality, either way there was going to be something to have to fix after, this was the lesser of evils.
Replacing door on brick wall. Missing lintel! Advice? wad2k Remodeling 2 04-25-2010 06:38 PM
1950s Bedroom Door Lock DeeJaye6 Carpentry 3 03-04-2009 12:09 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
anchoring door in a brick and concrete wall agroux Carpentry 1 05-08-2008 12:28 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
