Gambrel Math - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 08:34 PM   #16
Rewards Points: 506
Originally Posted by abracaboom
Each of the two rafters has a rise and a run; the rise of one rafter is the run of the other rafter, and viceversa. All of your dimensions depend on that right triangle with equal legs.
It sounded like you were enjoying yourself. If you want to have even more fun, try drawing it using only a straightedge and a compass.
Are you stating that it is possible to calculate the gambrel rafter length with ONLY the Pythagorean theorem?
jlmran is offline   Reply With Quote
Old 01-04-2012, 12:14 AM   #17
Retired carpenter
If anything, I would have implied it, which I didn't. But now that you mention it, yes, you can calculate the rafter lengths with ONLY the Pythagorean Theorem. It turns out that if you assign a value of one to the total run and the total rise, your rafters equal the square root of three minus one. In other words: rafter length = half the span multiplied by (the square root of three minus 1). If you draw your roof with just a straightedge and a compass, you will see clearly why.
Isn't that a more elegant solution than the span divided by 2.1796?
abracaboom is offline   Reply With Quote
Old 01-04-2012, 09:46 AM   #18
Rewards Points: 506
Actually for a hexagon gambrel the number is 2.732.
Old 01-04-2012, 10:54 AM   #19
Rewards Points: 506
Rafter length = (1/2 span) ((sqrt 3)-1)
Doesn't work for all gambrels....only for hexagon based gambrels...correct?
Old 01-04-2012, 02:30 PM   #20
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
I use autocad....it tells me the length....
but since your on #'s.....I understand now why a 5:12 roof pitch is so popular....easy to calculate the angles....
Old 01-04-2012, 02:48 PM   #21
Retired carpenter
Only for rafters of equal length at 60 degrees off of the horizontal and vertical lines, like the ones you drew, yes.
In a 90-60-30 triangle with a short leg of length one, the hypothenuse's length is two and the long leg's length is square root of three (by the Pythagorean Theorem). That's where the square root of three in the formula comes from. Thus, rafter length equals length of long leg minus length of short leg (that's what I call an elegant solution).
There is no "universal ratio" for all possible variations of a gambrel roof.
Old 01-04-2012, 04:00 PM   #22
Rewards Points: 506
I'm really dense. I'm still not understanding how Pythagorean theorem only can solve for the rafter lengths...especially given this image. Both roofs have an equal span and an equal height.
Old 01-04-2012, 04:06 PM   #23
firehawkmph's Avatar
Rewards Points: 1,884
Jlm,
I would think you would just have to break your drawing down to all right triangles, then use the old A sq. + B sq. = C sq. to find the lengths of each hypotenuse and add then add them up. Hope I remembered that right.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-04-2012, 05:33 PM   #24
Rewards Points: 506
Originally Posted by firehawkmph
Jlm,
Mike Hawkins
I don't see how that is possible IF the building span is the ONLY known value.
Old 01-04-2012, 10:09 PM   #25
Rewards Points: 506
Duh. Seems so easy now, after reading this.
http://erniedipko.blogspot.com/
Thanks to Ernie I feel quite dumb. Thanks to all for your input...I just wasn't getting it.
Old 01-05-2012, 02:25 AM   #26
Retired carpenter
Ernie's math only works for an octagonal gambrel roof. Note that on the kind of roof you drew, the one for which the ([sqrt 3]-1) formula applies, the rafters don't meet at the circle's perimeter, like Ernie's do.
You're still not using a compass, are you?
Old 01-05-2012, 06:38 AM   #27
Rewards Points: 506
Correct. It only works for the octagon.
It also took me a while to comprehend the 30-60-90 triangle, with sides of 1-sqrt3-2, but once I FINALLY realized that those values/angles are the basis for the trigonometric functions which I originally used to derive the denominators, then I had another ah-ha and felt really dumb. I had a trig class in high school in 1989...maybe I knew it once and forgot it.
I did use a compass to draw a circle around my protractor derived roofs. I'll need to play some more with it, w/o the use of the Chinese made protractor.
Old 01-05-2012, 12:54 PM   #28
Jl,
I was thinking you were working backwards off your drawings you posted. After reading Ernies blog, it all makes sense. Interesting thread.
Mike Hawkins
Old 01-06-2012, 04:32 AM   #29
Retired carpenter
A picture:
I used points A,B,C and D to draw a line perpendicular to the horizontal passing through A.
The circles with centers at A, E and F have a radius of length 1. On the NE quadrant I trisected the right angle NAF to obtain the equilateral triangle AHF to get my 60 degree angle. Point H is the intersection of the circles with centers at A and F. Half of the equilateral triangle is a 30-60-90 triangle (that's why its short leg is half the length of the hypothenuse).
On the SW quadrant I showed how to bisect an angle in order to get my 45 degrees using points A,E,I and J.
On the NW quadrant, point G is the intersection of the circles with centers at A and E. A line from E to G is at 60 degrees from the horizontal, and I extended that line to its intersection with the vertical line at point M. That gives me a 30-60-90 triangle with a short leg of length 1 (AE), a hypothenuse of length 2 (EM), and a long leg of length sqrt 3 (AM).
The 60 degree line EM intersects the 45 degree line AK at point L. Line EL is my lower rafter, and line LN is my upper rafter. Both rafters are the same length.
The circle with center at N has a radius equal to the length of the upper rafter and intersects the vertical line at M, meaning that the rafter length is equal to AM minus AN, that is, equal to ([sqrt 3]-1).
Old 01-06-2012, 09:33 PM   #30
Rewards Points: 506
Thanks. I will try to recreate this (and understand all of it) and report back to you. It might be a few days.
Building deck on side of Gambrel style roof - questions sheslostcontrol Building & Construction 14 05-10-2011 11:15 PM
Interior walls & gambrel ceiling Cveroline Carpentry 2 01-27-2011 09:54 PM
Insulating/Ventilating Gambrel roof billybarty Building & Construction 2 09-25-2009 02:17 PM
Gambrel Roof Measurements Hoff77 Building & Construction 2 03-15-2009 03:54 PM
math for checking for 90 degrees in a corner coderedcraze Carpentry 17 12-02-2006 12:40 AM
