Galvanized Nails Not For PT Wood? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2008, 10:57 PM   #1
Rewards Points: 682
galvanized nails not for PT wood?
I have always heard that it is okay to used galvanized nails for redwood and pressure treated wood. But I've just read a couple of internet articles stating that redwood, cedar and PT wood have acids that eat zinc, which means you should only use stainless steel or aluminum nails with those materials.
What gives?
darsunt is offline   Reply With Quote
Old 06-24-2008, 11:07 PM   #2
Registered User
Termite's Avatar
Not completely true. With pressure treated wood, you must use HOT DIPPED galvanized nails. Electro-plated galvanized nails don't have enough protection. Hot dips will work fine, or stainless is an expensive but better alternative. For redwood, I'd use stainless to minimize streaking.
Old 06-25-2008, 05:05 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Also, never use aluminum nails with Pressure Treated Wood.
- Build Well -
Old 06-25-2008, 09:43 PM   #4
Windows Plus
that is true. it will rust from weather
Kenny K is offline   Reply With Quote
Old 06-26-2008, 08:20 PM   #5
Actually, aluminum nails installed in PT will rust from galvanic reaction.
http://www.taunton.com/finehomebuild.../021160082.pdf
http://www.nadra.org/industry_news/acqarticle.html
- Build Well -
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
Don't use these nails on treated wood? scarrell Carpentry 3 04-01-2006 10:41 AM
