Galvanized Bolts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 09:21 AM   #1
Rewards Points: 14
Galvanized bolts
I built a deck and stair case using treated wood. On some of the posts for the staircase I used 1/2 x 6 galvanized carriage bolts. The rounded head of the bolt is on the inside of the stairs and the threaded part of the bolt is facing outwards. I cut off the remaining part of the threaded area and it is flush with the nut.
I'm looking for suggestions to coat the exposed part of the bolts to prevent rust.
worthspending is offline   Reply With Quote
Old 06-27-2011, 11:57 AM   #2
Too Short? Cut it Again!
Rust inhibiting metal primer and or galvanized paint.
Old 06-27-2011, 12:10 PM   #3
Rewards Points: 5,334
I'd switch the cut bolt for one the correct size. You won't get the same protection from the paint as the dipping.
Ron
B. Franklin 1759
Sprinkler: Splice PVC onto older NONthreaded Galvanized? kronic24601 Landscaping & Lawn Care 0 02-13-2011 03:18 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 09:53 AM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
Old Galvanized shower/bath inlets Relpace Pex? sssalas Plumbing 2 09-08-2008 03:56 PM
