Galvalum Roofing As A Ceiling? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 08:33 PM   #1
Galvalum roofing as a ceiling?
Hello all, Im wondering if anyone has ever used metal roofing sheets for a ceiling and soffit. Im adding a framed in patio cover and wonder if this is practical? Wanted the look of the tin as it fits my wifes decor? And if so, would the ceiling need to be insulated? The roofing is asphalt shingles?
outanup is offline   Reply With Quote
Old 06-01-2012, 10:43 PM   #2
Well my commercial shop has a metal Ceiling. I do know that we used a tin ceiling on an interior on a site already.. The only problem I see here is if that outside tin ceiling developed condensation to rust out later. Other then that tin would be fine if water doesn't attack it. i make sure you have cross ventilation so the tin can not build up condensation on the back side. As far ad insulation that could stop the tin from heating up and cooling down but again Cross ventilation is the key here..
21boat is offline   Reply With Quote
Old 06-02-2012, 08:28 AM   #3
Thanks for the tip, are you talking about soffit vents? Or maybe a ridge vent? any input will be appreciated......
Old 06-02-2012, 04:49 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Did you know that some soffit panels can be used as siding ? I have seen the galv ceilings and IMO they are pretty neat.
Roofmaster417 is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Another 2x6 cathedral ceiling juststarted Building & Construction 17 11-22-2011 04:27 PM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 10:30 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
