Old 02-01-2009, 02:22 AM   #1
Gaco Deck coating
Hi there , starting a new deck project 12ft, by 26ft, 9 foot off the ground,
want to use plywood decking with Gaco deck coating. Has anybody used it or had a chance to install it. comments please
Frederick j Ward is offline   Reply With Quote
Old 02-02-2009, 12:17 AM   #2
knewbie
curapa's Avatar
Gaco Deck coating
I haven't used it but please be sure you allow for the appropriate slope / drainage. Honestly it doesn't seem to be a product that is meant for residential homes even though the website mentions so. If you are looking to keep the space below the deck dry I would consider some of the between joist drainage products like DrySpace from Timbertech or similar.
Consider the tedious flashing issues and imminent rot that is going to occur around your posts.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 02-02-2009, 12:39 AM   #3
Gaco Deck coating
Frederick: I'm not familiar with this coating. It sounds like something you might roll on. Is that correct?
And is there any chance that you might be adding a roof above the deck?
Something either clear, i.e. glass, or translucent perhaps.
I spent several years in the deck business and there is always a solution out there to whatever it is you want.
cocobolo is online now   Reply With Quote
Old 02-02-2009, 12:54 AM   #4
Gaco Deck coating
Frederick: I just went to their website to check on the product.
A 50 year warranty and a 20 year track record seems pretty good. Especially with something you put on with a roller.
There used to be a similar product we occasionally used up here in western Canada, don't recall the name off hand, and it was nothing but trouble.
This may be entirely different given the more up-to-date chemistry and all.
The main problem with the stuff we used was that it would puncture very easily. Naturally, this would lead to water ingress. Once the water got inside, it didn't want to leave. The rot followed shortly thereafter.
I would suggest that you try and see if the company will give you a reference or two somewhere near where you are so you can check for yourself.
It may be just fine. But surface coatings are just that, coatings only. If it is going to get gentle treatment, it will likely be OK.
Old 02-02-2009, 09:26 PM   #5
Gaco Deck coating
Thank-you for your comments, I think i will do some more research though,i have seen this product used but have not applied it myself.
Old 02-03-2009, 01:34 AM   #6
Gaco Deck coating
put me on the skeptic's side,,, have seen many ' silver bullets ' over the yrs but not many have staying power,,, this 1 sounds too ' iffy ' for me.
yesitsconcrete is offline   Reply With Quote
Old 02-05-2009, 12:21 AM   #7
Gaco Deck coating
Yes, I most certainly have used the product you've mentioned. I give it 2 thumbs up and the easy button. I've had this product on my cabin deck now for about 10 years, so far no problems. Only wish I had some help from my brother while installing the product, but that's another story.
Mop in Hand is offline   Reply With Quote
Old 06-03-2009, 11:27 AM   #8
JT3
Gaco Deck coating
Fredrick,
I'm interested in the Gaco Deck product and was wondering if you completed the project? Thank you
JT3 is offline   Reply With Quote
Old 11-14-2009, 12:38 AM   #9
Deck Expert
Gaco Deck coating
www.deckexpert.com has info and advice on deck coatings and waterproofing
for roof decks over living spaces.
This picture is a failing pac poly diy application. Waterproofing decks over living spaces for traffic on top is a hard thing to do right...lear what you need to know at deck expert's website!
Deck Expert is offline   Reply With Quote
Old 11-16-2009, 11:05 AM   #10
JT3
Gaco Deck coating
Looks like bad prep or application to me.
Old 03-11-2010, 11:44 AM   #11
Gaco Deck coating
I'm new to this site and am planning on using the GacoDeck on my roof deck over the back patio on a home I am building. I originally was asking the guy at ABC supply about this stuff called DuraDec by Mule Hide who I am using for my modified bitumen roofing material. While I had him checking on a price I saw the pamplet for the GacoDeck on the counter and started looking at it. He noticed and said he would recommend that for out here where we live in Arizona. The DuraDec seemed to be like a laminate that you stick down and was brand new so he wasn't comfortable pushing that one whereas the GacoDeck he said is very popular in our area and the contractors have been pleased with it. Unlike what some have said on here that they are not sure if it is made for residential use or heavy traffic areas.. They add in crushed walnut shells to provide a slip-resistant texture granule finish to it, that alone should tell you what they are marketing it towards and from the feedback I've gotten around here checking with others who have used it, I am pretty comfortable with its capabilities.
Sonave Sunsets is offline   Reply With Quote
More On This Topic
When looking at a mule packing a load for camping or hiking trips, you may think the mule was born with this ability. It actually takes a lot of instruction to teach a mule to pack a load on his back, but you can train them to be pack mules in a few... Read More »
Hi, we're talking about skateboarding parts and maintenance. We're going to talk about the main part of a skateboard which is the skateboard deck. The skateboard deck is the wooden part that the trunks and wheels are attached to. The top is usually... Read More »
Hi! I’m Yvette Parish, and thank you for visiting expertvillage.com. Today, we’re going to be talking about high heels. These are slides or mules; you can call them mules. These are pretty with pants. You can wear them with pants; you can... Read More »
How to Raise Mules
How to Raise Mules by eHow.com
Mules have long had a bad reputation as being lazy and stubborn, but we should respect these interesting half-horse/half-donkey creatures because they are smart, cautious and can't be forced to do anything they consider dangerous. We refer to people as... Read More »
The other thing that you can do with a reversed card in a stripper deck is you can cut to it. This is actually a really cool thing to do if you're doing anything with a gambling kind of theme. Right now I have a card reversed in this deck and I can reach... Read More »
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
