Gable Vent-proper Installation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2007, 12:44 PM   #1
Malibu Mike
MIKEGOUGH1's Avatar
Gable vent-proper installation?
I am installing aluminum gable vents on my new garage construction. I have OSB for sheathing and I am using 4 x 8 Hardi Panels for siding. Do I install the vent before or after the siding?
MIKEGOUGH1 is offline   Reply With Quote
Old 01-22-2007, 01:58 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
After
Brik is offline   Reply With Quote
Old 01-23-2007, 10:19 AM   #3
Handyguy
Brik's Avatar
Opps, or before. I suppose it depends on the vents really. I have seen vents that screw to the outside and some that screw to the sheathing and are sided around. Do you have the vents yet?
Old 01-23-2007, 10:24 AM   #4
Malibu Mike
MIKEGOUGH1's Avatar
Yes I do, they have a thin flange all the way around them. It looks as though they should go up last, if I put them up before the siding, I would need something to trim the siding out with.
Old 01-23-2007, 10:35 AM   #5
Handyguy
Brik's Avatar
Yea, and with 4x8 panels this can be tricky but not impossible. Just screw them on and caulk them good then trim them out and caulk the trim.
Leaking gable vent jbinkley Roofing/Siding 6 02-05-2010 08:19 AM
Gable vent plans Cal General DIY Discussions 1 11-30-2008 04:00 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 05:59 AM
