Gable Roof Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 02:10 PM   #1
Gable Roof Span
How does one calculate the span of a Gable roof when determining the size of rafters to use. Is each plane considered a span or is the span the distance across the entire width of the roof? It seems to me that a gable roof is stronger than a shed roof since the rafters support eachother.
Gandalf is offline   Reply With Quote
Old 04-29-2010, 02:32 PM   #2
Old School
Willie T's Avatar
Actually, the rafters do not support each other... unless you use a ridge BEAM (not ridge 'board'). Then, in effect, you have two shed roofs butted together at the top.
Willie T
Old 04-29-2010, 09:45 PM   #3
Registered User
Rewards Points: 526
But if you remove 1/2 of a gable framed roof or the rafter ties/ceiling joists, it will fall down: http://books.google.com/books?id=E5S...raming&f=false
Be safe, Gary
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
Gable fan? Powered roof vent? idahojoec Roofing/Siding 2 07-25-2009 02:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
open span under hipped roof..... SickPuppy Carpentry 3 06-06-2008 11:24 AM
