-   -   Gable Roof Span (http://www.diychatroom.com/f19/gable-roof-span-70158/)
Gandalf 04-29-2010 02:10 PM
Gable Roof Span
How does one calculate the span of a Gable roof when determining the size of rafters to use. Is each plane considered a span or is the span the distance across the entire width of the roof? It seems to me that a gable roof is stronger than a shed roof since the rafters support eachother.
Willie T 04-29-2010 02:32 PM
Actually, the rafters do not support each other... unless you use a ridge BEAM (not ridge 'board'). Then, in effect, you have two shed roofs butted together at the top.
Gary in WA 04-29-2010 09:45 PM
But if you remove 1/2 of a gable framed roof or the rafter ties/ceiling joists, it will fall down: http://books.google.com/books?id=E5S...raming&f=false
Be safe, Gary
