Gable Louver Banging In The Wind - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 02:42 PM   #1
Gable Louver banging in the wind
Last night we had high winds and our roof turbines were spinning wildly causing a lot of air to come into the attic which pushed through the Gable Louver. It keep flapping, creaking, etc. so we sprayed it with a lubricant this morning. That should cut down some of the noise but I am wondering if anyone has any ideas on how to make it quieter. Should we put some weather stripping on the bottom of the vent?
Susan1661 is offline   Reply With Quote
Old 02-03-2011, 04:40 PM   #2
Rewards Points: 56
For starters, do you have soffit vents on your home? One of the roof experts is going to have to confirm this, but I believe that if you have soffit and roof vents, your gable vents are supposed to be removed or otherwise sealed anyway, in which case you could close them completely.
Old 02-03-2011, 05:10 PM   #3
Cool
No soffits
Thank you for the reply, glad someone at least answered! No, we do not have soffit vents in our house. The Gable vents are in the attic so when the attic fan is on, air can escape. However, as written, the wind was so strong last night, it made the turbines pull so much air in that the vents were opening, even though the attic fan was not on. It only comes on when the attic temp. rises too high, i.e. in the summer.
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 06:17 PM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 01:55 PM
Weil Mclain Boiler Banging After Water Circulator Swap Roamer HVAC 6 12-11-2008 07:42 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 08:32 AM
Changing gable over hip roof to gable end billybarty Building & Construction 2 03-11-2008 12:20 PM
