Gable End Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2013, 10:54 AM   #1
Rewards Points: 396
gable end wall
I have a quick question. Should you sheathe the gable end before or after adding a ledger and lookouts for an overhang?
detroittigerfan is offline   Reply With Quote
Old 08-07-2013, 01:00 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
we always attach the sheathing first
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-07-2013, 01:06 PM   #3
Rewards Points: 396
Ok then ledger flush with end gable rafters and then lookouts then sub fascia board?
Old 08-07-2013, 01:11 PM   #4
Rewards Points: 14,278
It would depend on how your framing the look outs. There's two different ways to do it.
And what do you mean by a ledger, I picture a ledger as what you put up on the house when building an attached deck.
Old 08-07-2013, 02:07 PM   #5
Rewards Points: 396
A ledger for the wall end of the lookout to attach to.
Old 08-07-2013, 02:19 PM   #6
kwikfishron's Avatar
Rewards Points: 996
As mentioned there are a couple of ways to frame outriggers (lookouts) neither involve a ledger.
kwikfishron is online now   Reply With Quote
Old 08-07-2013, 02:20 PM   #7
Haverhill Trade 1965
It sounds like you are using blocks for the lookouts as opposed to them crossing a plate at the top of the gable to the next rafter in, (a cantilevered lookout), correct?
Duckweather is offline   Reply With Quote
Old 08-07-2013, 02:26 PM   #8
Yes, like the picture that Kwik seems to have beat me to. The other way you describe is not a ledger but, I don't know if it has one. We should have a contest to name it!
Old 08-07-2013, 02:30 PM   #9
Rewards Points: 396
This is a shed and I did not frame a drop truss. After I sheathe the gable end wall what is best way to add the overhang? Can run a 2x4 against the sheathing flush with the end gable rafters then nail lookouts to that 2x4 then at the other end nail my 1x6 sub fascia board?
Old 08-07-2013, 02:38 PM   #10
Rewards Points: 996
If the gable wall has a double top plate you could do it like in the second picture.
How much overhang? How long is the fascia? You may not even need outriggers.
Old 08-07-2013, 05:59 PM   #11
Rewards Points: 396
Honestly I can't even really tell exactly how its framed in the 2nd picture. Fascia will be 1x6. As far as overhang I think around 10". When you say outriggers do you mean lookouts?
Old 08-11-2013, 10:13 AM   #12
Outriggers cantilever over the gable end wall. Lookouts are small blocks fastened to the gable end flush with the top of the gable end rafter.
Old 08-15-2013, 01:13 AM   #13
robertcdf's Avatar
10" overhang I wouldn't worry about a dropped gable. I haven't seen a home built with a dropped gable unless the overhangs were 2' or more. Usually they just nail the soffit to the subfascia and a 2x4 nailed to the gable, if you're lucky they might toss in a few blocks.
robertcdf is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
Attaching gable porch roof to wall grpie Roofing/Siding 1 02-23-2012 07:28 AM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 01:35 PM
