Gable End Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 06:41 PM   #1
gable end question
Hello,
Can someone please tell me how to install fascia for a end gable with no soffit or overhang? since there is no overhang no sure how to do the fascia part. Thank you.
markharmon is offline   Reply With Quote
Old 05-06-2013, 06:45 PM   #2
joed's Avatar
Rewards Points: 13,718
What type of siding? Can you post a picture.
I am thinking install the fascia and but the siding up to it.
Old 05-06-2013, 06:50 PM   #3
Vinyl. I dont have a camera. The fascia usually has a 3/4 lip on it though so that won't work.
Old 05-06-2013, 07:14 PM   #4
Rewards Points: 26
Is this new construction or just redoing the siding? Usually when there is no soffit you install a 1x6 or 2x6 along the roof line and the roof sheathing goes over it along with drip edge and then you use a piece of fascia to "wrap" the board and then side up to it. If you don't have anything how are you going to end your siding at the top and keep it water tight?
ponch37300 is offline   Reply With Quote
Old 05-06-2013, 08:50 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
the roof line (shingle edge)up the gable will determine what type of fascia is needed up the gable. roofing needs at least an inch overhang past the fascia depending on the type of roofing. A shingle rake over top the fascia butted to the roof line can also be added to extend the thickness of the fascia.
hand drive is offline   Reply With Quote
Old 05-06-2013, 09:50 PM   #6
My gable end is a 2x4. Should I just double up the end gable with a second 2x4? When I wrap it what kind of fascia can I use that I can tuck the siding into though?
Old 05-06-2013, 09:52 PM   #7
Can I add another 2x4 to the gable end to increase it by an inch and a half?
Old 05-06-2013, 10:05 PM   #8
AHH, SPANS!!!
is the roofing in place yet?
Old 05-06-2013, 10:18 PM   #9
No not yet.
Old 05-06-2013, 10:19 PM   #10
Hey do you know how to make a fascia soffit return box? I keep looking online and I can not find instructions.
Old 05-06-2013, 11:05 PM   #11
AHH, SPANS!!!
maybe a cornice is what you are referring to or a water table that wraps the overhang around the outside corner and returns back into the wall.
Old 05-07-2013, 07:48 AM   #12
Yes that is it. Do you know how to frame one? I can't seem to find instructions online.
Old 05-07-2013, 08:03 AM   #13
AHH, SPANS!!!
the overhang blocks that form the overhang can be taken to the outside of structure and cut to fit the angle of the roof rafter and installed up under said roof rafter forming the outside of the soffit. without details like size of overhang and pitch of roof I can only go so far with recommendations.
Old 05-07-2013, 08:41 AM   #14
6" overhang 7/12 pitch.
Old 05-07-2013, 09:10 AM   #15
When you install the sub fascia board does that have to be bevel cut at the top to match the roof pitch?
Old Work Gable Vent obricko Roofing/Siding 0 05-21-2011 10:53 AM
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 05:17 PM
question about gable overhang framing wombosi Building & Construction 11 04-09-2009 11:44 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
