Old 09-04-2014, 04:00 PM   #1
Rewards Points: 123
Gable end framing
My house under construction will have brick up to the level of bottom of end truss and vinyl siding on the gable. It is a block house (see photo) with 6/12 trusses for roof. The plan was to have two by twelves as the roof seal plate and have the end truss set on the edge overhanging the brick. The person that is going to help me frame is not sure that is a good idea and thinks the truss should set over the block and furr out the four inches to have the Osb and vinyl.
Would it help if I nailed a two by six to the bottom edge of the two end trusses and let that be inside and nailed to the 2 by 12? This is probably a common situation and please advise on the accepted way to proceed.
JM
ddsrph is offline   Reply With Quote
Old 09-04-2014, 04:41 PM   #2
Rob
Robpo's Avatar
Rewards Points: 520
Gable end framing
I would double the 2 by 12 before I would fir it out. I am guessing it is not going to be inspected since you don't ask your engineer or building inspector.
Robpo is offline   Reply With Quote
Old 09-04-2014, 05:12 PM   #3
Framing Contractor
Rewards Points: 502
Gable end framing
Let the side wall plates hang out from the block when you install them. Then you can rest the end truss on these cantilevered plates. We have done this many times.
Or you could have the mason install the brick first which would give you something solid to rest on. Either way is fine.
sixeightten is offline   Reply With Quote
Old 09-04-2014, 07:51 PM   #4
Rewards Points: 123
Gable end framing
Thanks for the reply. We are doing the brick first and I will post photo I just took a few minutes ago. The mason has only finished the wall shown and the brick and block are not exactly at the same height. The brick is about 3/8 inch lower. This is mainly due to the window locations and his trying to hit a happy medium on the brick at the windows and at the top. The j bolts are ten inch and in completely filled block work. I was thinking about taking some two or three inch wide 3/8 bar stock and bending angles with one leg about 12 inches and the other about 5 and bolt this to the j bolts and the short side into the bottom of truss. This would not only take the force off the edge of the 2 by 12 but would tie the end trusses down many times over a Simpson strap. I Have access to a iron worker machine at the local state vocational school.
Old 09-04-2014, 08:09 PM   #5
Framing Contractor
Rewards Points: 502
Gable end framing
You could probably lay some 1/2" sill sealer board over the brick to make up the height difference. I wouldn't be too concerned about tying directly to the face brick. As long as you are properly strapped/bolted to the block, you are fine.
The Following User Says Thank You to sixeightten For This Useful Post:
ddsrph (09-05-2014)
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
86 the Gable Vent??? 11thHourZero Roofing/Siding 5 07-17-2011 07:09 PM
Old Work Gable Vent obricko Roofing/Siding 0 05-21-2011 10:53 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
question about gable overhang framing wombosi Building & Construction 11 04-09-2009 11:44 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
