Gable Addition To Cottage. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2014, 08:59 AM   #1
Rewards Points: 95
Gable addition to cottage.
Im planning a small 10x10 addition for my cottage, below, can I screw the 'valley plates' directly to the tin roof, down into the rafters? Im not sure how to weatherproof under the valley plates though, as obviously water is going to get between the plate and the tin and into the roof. If it were shingles I could just flash under them, but tin?
I
wilyum is offline   Reply With Quote
Old 04-04-2014, 09:12 AM   #2
Rewards Points: 13,300
There's lots of different style "metal" roofs, which one do you have?
If I was doing it I'd remover the roofing so I could install a valley.
Old 04-04-2014, 05:52 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
for metal you will have to take the metal off the main roof the width span the addition is going to be and re cut the roofing to the addition. if there is a seam in the main roof and the addition stays below it then you could take from the seam down
hand drive is offline   Reply With Quote
Old 04-04-2014, 11:21 PM   #4
Registered User
Rewards Points: 5,236
May want to figure the added snow load on the existing rafter span also.... struts/purlins or sistering may be in order.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
hand drive (04-05-2014)
connect one existing gable roof to an addition im building onto house at end in an l shaped design srdavis Building & Construction 4 01-28-2013 09:58 PM
adding workspace addition to a gable style garage builderzone Building & Construction 2 09-05-2010 05:22 PM
Cross Gable roof porch addition ehowardal21 Building & Construction 1 09-03-2009 05:10 PM
Adding shed addition to gable roof desch Building & Construction 2 08-31-2009 10:19 PM
32x10 Porch Addition with Gable Roof my5sons Building & Construction 4 11-17-2008 10:12 PM
