Furring Strips Or 2x4s Against Concrete Basement Wall? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 03:49 PM   #16
Originally Posted by denemante View Post
But back to the vapor barrier - it scares me a bit. My basement stays bone dry. I'm fearing that a vapor barrier might then trap moisture behind it where mold would grow. If I don't use one and let it all sort of breathe - what's wrong with that?
Mold needs food to grow. If you put drywall with a paper backing on the concrete, then mold could grow on the paper.
If the walls are clean and you put a plastic or foam vapor barrier up, then there's nothing for the mold to grow on. You might get water, but you won't get mold.
I'm kind of in the same boat as you. Here in South Carolina our weather is a lot like Atlanta. The basement is dry and mold free, and I don't want to mess that up!
pyper is offline   Reply With Quote
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
fiberglass insulation against concrete wall mike4 Building & Construction 4 03-27-2009 10:48 AM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 02:48 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Advice needed for Basement Wall nh10ring Building & Construction 5 02-08-2008 06:45 PM
