Furring Strips - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 09:38 AM   #1
furring strips
adding 2x2 to 2x4 leaves me short of a 2x6 for R19 Do I have to add the full 2" to recieve credit for full R19 value for my energy calcs.
Lon Huntington is offline   Reply With Quote
Old 12-08-2011, 09:42 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Correct.
Andy.
AndyGump is offline   Reply With Quote
Old 12-08-2011, 09:54 AM   #3
Thanks for the quick reply Do I have to fur a full 2" for full R19 performance
Old 12-08-2011, 10:04 AM   #4
AndyGump's Avatar
Rewards Points: 660
Yes.
Andy.
Old 12-08-2011, 01:44 PM   #5
DIY or die !
Rewards Points: 77
how common is this practice?
lewisthepilgrim is offline   Reply With Quote
Old 12-08-2011, 05:24 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
in renovtions where the existing framing is 2x4 and local codes dictate bringing the insualtion up to a minimum of r-19 quite often, especially if spray foam isnt in the budget.
locally r-24 is required, its the same thickness as r-19 but is a more densely wound insulation.
the problem with using 2x2's is that they are only 1 1/2 x 1 1/2" you need to add the full 2" thickness otherwise when the drywall goes on the insulation will compress which reduces its effectiveness. your better off buying 2x 6's and ripping them down. you will have waste but it can easily be used as fire wood or kept handy for ripping thinner furring strips
woodworkbykirk is offline   Reply With Quote
Old 12-08-2011, 05:26 PM   #7
AndyGump's Avatar
Rewards Points: 660
Not very common here in California, R-13 in 2 x 4 walls is standard and prescriptive in most places except perhaps the mountain communities.
In ther colder climates in other states it may be a more common practice.
Andy.
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Furring strips on top of XPS? randall.miller Insulation 6 08-27-2011 08:39 PM
(Basement) Furring strips vs Traditional framing? ctote Carpentry 15 07-21-2011 01:00 PM
Attaching 12/2 wire to Furring Strips blaze01 Electrical 2 02-17-2010 02:17 PM
Furring strips on peaked roof zantar Building & Construction 6 11-18-2009 10:46 AM
