Furring Strip Spacing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 03:37 PM   #1
I am getting ready to put up furring strips on my basement ceiling so all of the pipes are hidden. I am going be using 2x4s laying flat. If i put them 16" oc then they high hats dont fit. Can i do it so they are 24" on Center? or 18" oc. I don't want to make more work for the drywallers. I am afraid if i do it 24" oc i will have sagging issues down the line which i dont want.
Thanks in advance.
Nick
nsanto17 is offline   Reply With Quote
Old 01-13-2011, 04:21 PM   #2
you could use 5/8" drywall. You could also use 1/2" and glue it. Since a 2x4 24"oc leaves 20 1/2" inbetween, the glue would utilize the full width of the 2x4 in a way that just screwing wouldn't.
mrgins is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 04:52 PM
furring question in steel building madjuna Carpentry 2 02-01-2009 10:47 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
