Old 10-12-2009, 02:57 PM   #1
Furring out walls for insulation?
Ok,
so from my understanding, I wll need to furr out all of my existing 2x4 walls in my attic (approx 825 sft) so I can use R-19 insulation.
A heating/cooling rescheck was done from the building inspector, and in order for my attic renovation (house is only 3 years old?) to pass inspection or to continue, the walls around the windows in attic need to be furred out to be 5 1/2 inches for r-19 insulation.
There are alot (5) of window dormers in the attic, so my question is can we use 2x3 which would bring the wall out 6 inches? What potential issues can happen by doing this?
The cathederal ceilings are 9 inches would be R-38..
Any other ideas?
ddave23 is offline   Reply With Quote
Old 10-12-2009, 04:11 PM   #2
47_47's Avatar
Can you have a closed cell insulation sprayed in? I think you get an R value of 6 per inch or an R21 in 2x4 walls.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 10-12-2009, 04:14 PM   #3
Thank you for your response.
I was looking into that as well, but wasn't sure if that was possible with the spray foam insulation. Can this be done only to the window doormers? or would i have to spray foam the cathederal ceilings as well?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 03:50 PM
