Furring Out Existing 2x6 Rafters - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 09:57 PM   #16
Rewards Points: 626
go to this link it will help you out the best.
http://www2.wwpa.org/
Nailbags is offline   Reply With Quote
Old 02-11-2012, 10:22 PM   #17
Registered User
Rewards Points: 5,460
You may need a vapor retarder or a vapor barrier, or simply nothing there......
Where are you located?
Gary
Old 02-11-2012, 10:23 PM   #18
Gary
South NJ
kirylm is offline   Reply With Quote
Old 02-11-2012, 11:38 PM   #19
Registered User
Thanks, it appears you are in Zone 4; http://www.spore-tech.com/viewCatego...?idCategory=78 Check under the map for the major City listed close by.
R-38 is required in the ceiling; http://publicecodes.citation.com/ico..._11_sec002.htm
This will give you some new guidance: http://docs.google.com/viewer?a=v&q=cache:EJENK_uA9RQJ:www.cr-ar.com/pdfs/Building%2520Code%2520Changes.pdf+R602.3(1)+2006&h l=en&gl=us&pid=bl&srcid=ADGEESh311Kosslp7jsjp9WhUX xZsgSiyNaWb-eW0YminVwmPUavLlW75BKLoV9em4LFCAydmTGQlkUFOPm8AqHk RP5wLQGQQGkwyzAGtlN4D2DqCiCLwprOpEbvvjeGk6CEhyHiVd tK&sig=AHIEtbRa4Ah_IICPQ3BR1txlzU01V4JQIg
Egress stairs, egress windows, smoke detectors, etc. are all required. A permit is required for the "change of use" and the paper trail is essential for any H.O. Insurance future claims and at resale time.
The vapor barrier requirements: http://www.buildingscience.com/docum...commendations/
Gary
Old 02-12-2012, 01:21 AM   #20
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Hi, I don't mean to be an a$$ but there are a ton of things that I can see that might be wrong with your plan.
For now I will just concentrate on the following:
It sounds like you are going to have to install ridge venting and eave venting for every eave.
Have you made plans for this?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-12-2012, 08:16 AM   #21
Andy.
Yes, the ridge vent is already there, I will add eave venting (sort of soffit vents) later on.
What other things are wrong?
Old 02-12-2012, 10:30 AM   #22
Really cool post, highly informative and professionally written..Good Job
Gaines21 is offline   Reply With Quote
Old 02-12-2012, 06:06 PM   #23
Originally Posted by Nailbags View Post
your floor joists are 2x8 correct? can you read a lumber stamp? if you can can you tell me what kind of lumber it is? is it Doug fir larch? or Doug fir?
Found a stamp that says: SPIB No.1 (433)
Can you post that formula you mentioned?
Thanks!
Old 02-13-2012, 12:05 AM   #24
Registered User
http://publicecodes.citation.com/ico...002_par017.htm
What is the end result for this space?
Gary
Old 02-13-2012, 07:45 AM   #25
Gary
Finished bedroom
Old 02-13-2012, 09:35 AM   #26
Framing Contractor
Originally Posted by kirylm
Finished bedroom
You'll need permits...inspections....egress window.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-13-2012, 10:54 AM   #27
I appreciate all the advices.
Just to make it clear, currently that area has 2 finished bedrooms. I am not creating any new living space, just re-doing the existing design. The problem originated from the fact that it gets hot (way too hot) in the summer, and too cold in the winter. That's why the whole idea of putting proper insulation, creating air channels, etc. Plus i wanted to install knee-wall cabinets and put hard wood floors instead of carpet.
It does have large windows, much wider then the 1st floor (I guess that is considered egress?) I never heard of egress windows on the 2nd floor, they usually do this in the basements...
Old 02-13-2012, 10:10 PM   #28
Registered User
Egress windows are to enable a fireman with an oxygen tank on his/her back to get in/out safely; http://www.aacounty.org/IP/Resources...ementGuide.pdf
The 5.7 sq.ft. clear-opening window is reduced for at grade windows: http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Gary
Furring strips on top of XPS? randall.miller Insulation 6 08-27-2011 07:39 PM
(Basement) Furring strips vs Traditional framing? ctote Carpentry 15 07-21-2011 12:00 PM
Splitting an existing circuit run JoeyBradshaw Electrical 1 09-24-2010 08:02 PM
Furring out a 2x4 wall to a 2x6 wall artandpats Building & Construction 4 08-09-2010 10:14 PM
join new crawl space CMU footing/foundation to existing CMU basement wall CapeCod153 Building & Construction 4 08-04-2010 07:35 PM
