That i completed I have Furnance question Okay, I have completed my basement project as much as possible and it definitely made a big difference in the comfort level. But now I have a question about my furnance.
Now, that I have completely blocked all the gaps and cracks in my basement walls and at the rim joists, there is hardly any fresh or outside air coming into my basement. Then, doesn't my 80% furnance need outside air to burn gas more efficiently? There is no fresh air intake for my furnance. What I have been doing is opening one of my tiny rectangluar glass window just slightly enough to let some air into the basement for my furnance. But people I talk to tell me that I don't need to do that and that I already have air in the house to heat and circulate. I may look dumb (LOL), but I learned in my science class that fire needs fuel, oxygen and heat to burn at its best. If my furnance burns off most or all oxygen in my basement, how is it going to burn natural gas. Also, that if you seal all your cracks and gaps, there won't be air in the basement for the furnance byproduct, carbon monoxide (CO), to run out the chimney. Instead, the negative pressure will pull outside air through the chimney and flood CO into your house.
I am baffled. What is the real soultion? Please, help. This is my first time owning a home. So, I am learning as I go.
I provide a two 6" ducts to the outside to supply fresh air to a furnace, especially since I normally have it in a small room. One vents at the base of the wall and one at the ceiling. This creates a natural air flow without any fans. You can feel the cool air flowing into the furnace.
Don't worry about that...there are 1001 ways air can get into your furnace room that you (or anyone) really doesn't even know about. The laws of thermodynamics take care of air concentration gradients.
You are out of your mind. I know negative pressure will pull outside air from 1001 places, but do you really want outside air to leak into your house from 1001 places. For that, you would rather open all your windows and doors in your house during winter season. When I bought the house, I had plenty of outside air coming into the house like 10000001 cracks and gaps. We were wearing coats and winter gloves the first winter inside the house. We were horrified that no matter what we set the thermostat to, it was cold and the furnance kept running and running but not enough heat.
Furnance defintely needs fresh outside air for combustion, but you have to have control over the fresh air intake or cold outside air will cool all parts of your house. I am sure you don't want that. I bought the house as-is and the basement was unfinished. When I inspected the basement, outside air was gushing into my basement through basement cinder block walls all the way around hitting my rim joists and cooling my first floor. Thus, cooling my living room and kitchen no matter how much we set the thermostat at. After spending nearly $1000.00 on insulation and plastic sheets, I made an effort to seal all these gaps and holes and cracks in the basement. Now, our comfort level has gone up and my furnance doesn't run and run all the time. The only problem I am running into is fresh air intake for my furnace. Now, that I completely seal all my basement, there hardly any fresh air entering my basement for my furnance. So, I leave one of my basement window very slightly open just enough for my furnance and that it won't cool my whole basement. However, this is only temporary. I want to put something in place permenantly. So, I don't have to worry about it.
Please do worry about it. If you've made your house a lot tighter you could be causing incomplete combustion and inadequate draft through your furnace. Hopefully you already have CO detectors in the house (any house with gas should have them). It would be worthwhile to have an HVAC tech come in and check your furnace combustion (they have fancy combustion monitors) to determine whether you nedd an outside air supply.
Whatever, diy4...I guess you live in the only house so airtight it qualifies as a research project, and all based on the huge sum of $1000! The "Theoretical House" you should call it.:laughing:
After what I've done to my basement, the house is atleast livable. Before there was no difference in the outside or the inside tempature. I do understand that the furnance needs fresh air for combustion. That's why I leave one of my basement window open slightly all the time. So, even if the furnance is not running fresh air is always filling the basement. Whenever my furnance starts running, it will have plenty of fresh air to run on.
I am well aware of the danger. I am just looking for ideas on DiyChatroom.
The position of the air vents for an open flued appliance is important. A vent on the windward side can bring in excessive amounts of cold air, while one on the lee side may actually suck air out. One in a neutral position would be the best place.
It is usually best to vent from another room like a hallway if possible, and then vent this room, or run the vents through ducting in the floors to prevent cold draughts.
Living space of house is only 30ft x 20ft two story house with basement. So, whenever my furnace runs it pretty much pulls most of the air from its immediate surrounds creating negative pressure. So, air is always being pulled from outside never sucked out.
I do have a 6" vent hole near the floor for my dryer. I am not sure if I can use it also for furnace fresh air intake with some sort of flap damper.
I have a fairly tight townhouse. Older efficient windows but little air leakage. Even if they are high efficiency, they are still just a hole in the wall when it comes to radiant heat loss at night when a curtains or drapes do more good that all of the films and gases in between the panes.
My units was built in 1980, but the code required a fresh air intake for combustion (gas furnace, hot water heater, dryer). I have a 6" flex vent from above the roof or between the insulation and the roof. I could feel the cool air coming in continually due to the natural stratification. I put the vent pipe into a 5 gallon pail and close the door to the laundry furnace room. When the furnace or heater run, I can feel the cool air coming in through the vent, but there is little when they are not running. The siphon effect coupled with the draw of units when they need combustion air works!!
Fresh air is not required for combustion. I don't care if the air is fresh stale or stinky.
There are 3 things required for combustion. Fuel, Oxygen, and an ingnition source. Oxygen is present in all our air otherwise we would all die from suffication.
Oxygen is present in our atmosphere (about 19-22% concentration)
Its what we breath, and its what your furnace breathes.
It is fine to have a fresh air vent but absolutely not required. Oxygen is present in the atmosphere around us. If a house was truely air tight, eventually the carbon dioxide we exhale and the bi-products of combustion (carbon dioxide, carbon monoxide, water, etc.) would eventually use up all the oxygen in the house's atmosphere. But! No house is air tight. All furnaces are vented for exhaust. My hot water heater and furnace are in a finished basement room, all closed up in the winter, with no vent and we have no problems at all. Oxygen is all around us and gets in every time we open the door, threw every microscopic crack in your house and every window / door frame. Hell it even slowly permiates the walls of your house.
You furnace is fine and I gaurentee unless you pump pure oxygen into your boiler room (Not recommended) you wont notice a difference in efficiency in your furnace with a fresh air vent. In fact you'll probably loose efficiency because of the cold air entering your 6" vent that now has to be heated.
If you are that worried about it have an air infiltration test run
They put a blower on the sealed front door & provide an analysis on whole house infiltration
I really doubt what you have done has had a major effect on the average air change for the house:
The US national average of air change rates, for existing homes, is between one and two per hour
You were probably MUCH worse then this & have now brought your house closer to the average. I replaced all the basement window, sealed & insulated the rim joist & replaced all the windows in the house
I'm not in the least bit worried about incomplete combustion
Thank you for your reply. I am sorry I keep using Fresh Air Intake. Fresh Air Intake deals with cold air return in your furnace. What I meant to say was outside air for efficient combustion. You are absolutely right that Oxygen is good percent of our atmosphere and that it does seep through cracks and gaps and walls in your house. However, in an enclosed space with a furnace that needs plenty of Oxygen to burn at its best, you need some ways to replenish the depleting Oxygen in the immediate surroundings. Outside Air doesn't just only help your furnace burn efficiently but also you won't have back draft forcing CO and CO2 to fill up your house.
Why do you think High Efficient Furnaces (90% or 95%) have ducts that directly pulls air from outside and runs it through the furnace? That's part of being highly efficient. In other ward, flame heating the heating element in the furnace gets to burn at its best when it gets plenty of outside Oxygenated air. Thus, the furnace heats the circulated air much faster and hotter.
I used to close all the windows and doors tightly as possible thinking that it will prevent heat loss, but as I kept reading about how furnace works and how some of them are highly efficient I learned that the major difference between low efficient and high efficient furnace is the insulated duct work that pulls outside air for combustion. At least that's what I have been told by many contractors and people.
From my personal experience, I can definitely agree with that. Whenever I had all my windows in the basement closed shut, my 80% furnace hardly put out any hot air and sometime less than warm air. Plus, my furnace would run and run for 15 to 30 minutes every 15minutes. After my basement projects and leaving one of my basement window slightly open for outside air, my furnace blows hot air every time and it doesn't keep running for 30minutes to reach the set temperature. It takes only 6 to 8minutes for it do that. The living space is much more comfortable.
Try running your car after stuffing your air intake with cloth LOL.....
You will eventually come to a stop completely. :laughing::lol:
If you aren't getting hot air out of your furnace then you have a problem with your furnace
Every door & window is tightly shut in my house
I caulked & sealed every air leak I could find
My system runs at 86% efficeint & I'm not worried
I also burn wood during the winter to help heat house
That takes a heck of a lot more air then a funace as its going constantly
You for sure need the intake and exhaust vents installed in your furnace. They'll use PVC pipe much like plumbing drainage. One sucks air in, the other blows out (the CO) .
If anything it's better to have a slightly positive air pressure, then negative.
All I know is this. The more negative pressure you create anywhere in your house the more strain and stress you will create for your furnace motor to run. This can lead to motor burn out eventually and/or back draft causing
CO and/or CO2 to fill your basement.
There were times when I used to close and open one of my basement window routinely to see how my furnace acted and one time I totally forgot for a whole day. My family and I started to feel a lots of headache and dizzness. Then, I remembered and thought maybe it's because of the fume from the furnace filling my basement. I right away opened the doors and windows for fresh year. Within 15 minutes of doing that we felt real good and no headache. From then on I left one of my basement window open slightly. Since then we never felt anything like that.
Before buying the house, I walked through it with the homeowner and at some point I noticed she had a portable CO monitor plugged in the living room, halfway and the bedrooms. I asked her about it and she told me that it was for "accidental" safty and there was absolutely nothing wrong with the house she insisted. Now, I know why she didn't tell me the whole story. Not only that, at the time of closing on the house inspector noticed her furnace was broken. Home inspector ended up requesting the homeowner to get technican in to check out it closely. According to the technican, the heating element in the furnace was totally beyond repair. At the end, the homeowner replaced the old furnace with a new one.
Just goes to show that the whole house was poorly insulated and the furnace must have been beaten to death, because the house couldn't keep the heat. As a result, she completely shut every windows and doors down. Thus, creating negative pressure in the basement. This negative pressure tried to pull outside air from every part of the house even through the window's cracks and gaps, but probably not much leading to CO or CO2 backdraft requiring CO monitors.
I still can't believe she stayed in our house for 18 years with all these problems. I am really having hard time accepting that. She wasn't young either but 70 years old, when I bought the house from her. Scuba if you or your family feel slight headache, I suggest you let in some fresh air from outside. If everyone feels headache, its not normal. I am not joking here either. :laughing::lol:
These are bare minimum codes, remember: Combustion Air �� The minimum duct cross section dimension is 3”. (M1703.2.1 for oil and G2407.6 for gas) �� No dampers in combustion air ducts. (M1701.3) �� Sources of combustion air > 10’ from return air. (M1602) �� Joist and/or stud space ducting ok only if a maximum of one fire stop is removed. (G2407.11) �� Openings screened (except in attic) with 1/4” mesh. (M1703.5) �� Opening sleeved to 6” above ceiling joists and insulation. (M1703.3 & G2407.11) �� Combustion air obtained from outside of the building when the building is of unusually tight construction. (M1701.1.1) (Typically homes built after 1986) 1. Minimum of 100 sq.in. per opening of combustion air is required. 2. One opening in upper 12” and one opening in lower 12” of room. �� Combustion air obtained from outside of the building, when the building is of ordinary construction (homes built prior to 1986) and the area of the room is less than 50 cubic feet per 1000 Btu/h of aggregate input rating of appliances. (M1702.1) See also Construction Tip Sheet 7, Water Heaters. 1. Minimum of 100 sq.in. per opening of combustion air is required. 2. One opening in upper 12” and one opening in lower 12” of room. (UMC 702.1, see exception) 3. Where vertical ducts are used each opening requires 1square inch per 4,000 Btu/h of total input rating of all appliances in the space. (M1703.2.1) 4. Where horizontal ducts are used each opening requires 1 square inch per 2,000 Btu/h or total input rating of all appliances in the space. (M1703.2.1) 5. When the one opening method is used. 12” from top of enclosure 1:3000 Btu/h or total input rating al all appliances in the space. (G2407.6) �� Only the lower of the two combustion air openings can be connected to an underfloor area. (M 1703.4) �� Foundation vents supplying underfloor area minimum 2x required combustion air openings. (M1703.4) �� Crawlspace must meet minimum International Residential Code clearance of 18” from soils to bottom of joists. (R319) �� When combustion air is obtained from the attic the attic must be sufficiently vented. (M1703.3) �� Combustion air openings of correct size. (M1701.5) From: http://www.mybuildingpermit.com/Inspection Checklists/03IRCMBPMechanical rough in checklist.pdf
That is certainly a long list of minimums that must be met to meet the bare minimum requirements. - It seems beyond the realm of the real world considering the quality of existing construction in the U.S. It is fortunate in a way, that the typical U.S. construction is leaky frame construction that will always provide some infiltration for combustion in one way or another.
Seems this is exactly what I was addressed with the two duct venting that I install. Beauty of the system is no mechanicals so nothing to fail. Air only flows when the furnace needs it.
My house was built in 1921. How old is yours Staurt5? Just curious.
You know you guys.. Maintaining code is one thing, but when it comes to creature comfort, it is totally something else. If you are not comfortable in your own house regardless of how crappy it is outside, then maintaining code means nothing. As long as you are a very responsible person and have the general knowledge and commonsense, then you really don't have anything to worry about as for as codes go.
Government will come up with as many codes, rules and laws as they want and see fit to make money, but ultimately it will be in your hand to make sure you don't do anything stupid and burn your house down.
I am not an electrician, but I know I have enough background to install circuit breakers and run a wire for my electric dryer.
My cottage is about 350 years old, give or take a year. Quite a new one for his area. Owning an old house is a hobby, as the list of jobs is endless, especially with my wife writing out the list.
Code is a guideline to provide the bare minimum standards. As professionals we build far beyond code requirements. You are suggesting to build below these standards? That is just STUPID. Codes are written to protect the public not to collect money. The codes for electrical work are written by the fire protection agency. The new codes are developed by studies of what is killing people and starting fires. Based on you signature and your statement about code compliance I can see you have a very tough life.
I totally understand what you are saying regarding fresh air.
Example: Old time fire places had air vents through the walls to supply air to the fire box that way the burning fireplace used the outside air without drawing all the heated air from the house into the fire and up the chimney.
Your heater can work the same way use outside air to feed the fire and not draw already heated air through the heater and out the flue.
Same principal as today's high EFF heater's.
Can't wait to hear from other's I am plugging my ears as I type.
Diy4, you should have quit days ago; re-read the adage that says you should use your ears twice as much as you talk. And change your monicker; you're starting out on a DIY path that's already wrong.
Carsile must have taken personally what I said previously. :no::laughing:
I am so sorry if I hurt your feeling my friend.
As for as codes, I don't mean built houses below standards. Everyone should take all the necessary steps to prevent any accident and protect your property. That doesn't mean open all your doors and windows to keep fresh air circulating through the house and freeze your ass. My house is above and beyond any codes you can think off.
i know im probably going over old ground with this but with the gas boilers i work with they use a 600mmx600mm louvred panel for air flow and the plant room stays reasonably warm.
the louvres help to stop direct wind blowing in and also arent open enough to allow the suction effect of a down wind,
i have been reading all the above comments ragarding a air intake, i also have a wood furnace in the basement, and i was told i 6 inch air intake would be good, now i beleive that it need to be brought into the basement and brought down the wall to the floor, i have also been told that one of these will work great http://www.energyfederation.org/consumer/default.php/cPath/30_744_546
what do you think :whistling2:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
