-   -   Funky Odor in Garage (http://www.diychatroom.com/f19/funky-odor-garage-158090/)
mikeyp78 09-26-2012 07:05 PM
Hi there! A friend of mine recently bought a townhome. His garage has this funky - almost rotten garbage - type smell. He had the lower half of the drywall removed to see if there were any dead critters in the walls which ended up just being a waste of time and effort. Two things we recently found out were: 1) the previous owner had a fridge in the garage which broke and flooded a portion of the garage with rancid liquids, etc. 2) There is an exposed clean-out plug that goes directly into the bathroom. So now we're thinking that the smell could be a result of one of those two things.
Thoughts on that?
My friend was advised to acid etch the concrete slab and cover with an epoxy or diamond sand the concrete slab then apply the epoxy (no acid etch). Do either of those sound like a good solution? Before we spend some money and tackle this ourselves, we want to make sure that these solutions might solve the problem.
Thanks folks!!!
Mike :thumbsup:
allthumbsdiy 09-26-2012 09:29 PM
Does the odor get stronger (you will need to get on the ground and get your nose next to it) in the supposed "rancid spill" area?
Before going through all that trouble of etching with acid, I would try pouring some straight laundry bleach on it, let it sit for a while and rinse it off to see if it makes a difference.
As far as the cleanout plug causing the smell, simply wrap a large plastic around the top and seal it with duct tape to see if the smell goes away.
If none of the above makes any difference, can you open the garage door(s) for awhile and (again) use your nose to smell around the garage to identify the offending spot or spots?
Many garage studs have fireblocks about midway up the wall and can potentially have dead things on or above it.
Good luck
PS. I presume that your friend lives in NJ as well? Being that I also live in NJ, his townhouse is not near a dump or some chemical factory, correct? :)
chrisn 09-27-2012 04:57 AM
Good luck
Isn't everything( next to a dump or chemical factor) in NJ?:whistling2:
hand drive 09-27-2012 08:56 AM
the toxic overflow could have seeped under and soaked up into the walls also, that would be hard to access and bleach away...
Maintenance 6 09-27-2012 11:51 AM
I assume there are no floor drains or laundry sinks on the area that may have a dry trap?
mikeyp78 09-27-2012 06:27 PM
Good luck
The odor is definitely stronger towards the entrance into the house - where the fridge (the one that leaked the rancid water everywhere) used to be. It is also right around the location of the cleanout plug.
mikeyp78 09-27-2012 06:28 PM
No floor drains or laundry sinks.
mikeyp78 09-27-2012 06:31 PM
Closest chemical factory is about 5 miles... dump is about 15 miles (that's in PA, though). Trust me, I have campaigned to move out of this state for years... my wife doesn't want to move.:pinch:
allthumbsdiy 09-28-2012 09:04 AM
wrap and seal that clean out to see if the problem goes away.
if your nose says its the concrete, you can rent a small electric demolition hammer and remove 2-3" from the top.
good luck
ddawg16 09-28-2012 11:51 AM
If you get the floor wet...does it change the smell? Make it stronger? If so...then it's your floor.
If bleach does not work....try ammonia....or vinegar
