Full Piece Of Sheathing At Garage Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 06:28 PM   #1
Full piece of sheathing at garage door
Do the edges of the garage door need to be sheathed with a full piece? Of course, the piece would have to be notched out (it will look like an upside down L). I was going to use some scrap pieces, unless it isn't advisable to do so. The garage is a gable style structure with the door cut out of the end.
pomelo is offline   Reply With Quote
Old 04-03-2009, 08:20 PM   #2
Registered User
Rewards Points: 526
Yes, try to use as large a piece as possible. With the big hole cut in that end, it doesn't leave much for structural shear. But mainly I would follow the plans. The wall will have been engineered for all stresses involved and you wouldn't have a worry it could blow or fall over. That's where "shear panels" come in, special bolted, special nail pattern, certain minimum width, and extra stud members. Scraps are just that. Be safe, GBAR
Convert garage door to high lift door? 65cobra Building & Construction 5 06-23-2009 08:38 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
garage door removal and replacement TVC15 Building & Construction 5 08-13-2008 05:30 PM
Garage door disengaged auto opening pharndt General DIY Discussions 5 03-02-2008 10:50 AM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
