Frustrating Yellow Bleed Through On Plaster - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 03:26 PM   #1
Frustrating yellow bleed through on plaster
I have been attempting to repair badly water damaged plaster walls in a 90 year old brick house. In some cases I've had to remove the wall back to the interior brick and rebuild. Other places I've been able to scrape the crumbling plaster back to what feels like solid wall then begin applying layers of Sheetrock Easy Sand 90 Lightweight Setting-type joint compound.
Problem: I continue to find patches of yellow-orange coloration that bleeds from the old plaster wall through the new joint compound. These places are not only unsightly but are prone to flaking. In some cases, whole patches of dried plaster just falls off when I go to scrape it in preparation for the next layer. This is hellishly frustrating as I've tried Water-based KILZ, Oil-based KILZ and PVA to try to block this effect.
Is this some kind of mold or other organism that has taken up residence in the wet plaster? Am I doomed to tear all the plaster out just to get rid of it?
CraigSMc is offline   Reply With Quote
Old 07-18-2010, 06:28 PM   #2
Rewards Points: 5,336
Is this plaster directly on a solid brick wall(not veneer brick)?
Is the brick wall wet or moist? It could be the minerals from the brick or mortar are leaching out to the plaster, depositing salts in the wet plaster.
How was the brick wall tested for dryness before the plastering process started?
Ron
Old 07-18-2010, 06:37 PM   #3
Ron,
The brick wall is solid.
Other walls that I've opened up (pulled all the plaster back to the brick) have been musty and wet. I had the roof repaired, but it appears that a good deal of water was already in the wall. Those walls that I've opened, dried by leaving a dehumidifier in the room for several days, and then re-plastered with Structolite seem to not have this problem.
I do not know how to test for dryness other than smell and touch.
Old 07-18-2010, 07:01 PM   #4
Moisture meter is what you want.
You can't assume all the walls were at the same level of, "wet". Walls facing South and West will dry faster then walls facing North and East. Unless some walls got wetter to begin with, or trees are shading some walls, etc. Bottom line is that the wall needs to be dry and you need to that before you start finishing them. Because if you don't... well you know what happens.
Ron
Tags
bleed , plaster , water damage
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 07:42 PM
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 12:50 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
