#1 |
Frosty wall
I am going to piggy back off this old post. I have attached an image of what is going on in my garage. It seems like the wall if more moist the further down you go. Is this something I need to worry about and get fixed?
#2 |
Frosty wall
Got a picture of the outside of the house in that area.
Sure looks like you have some air leaks around your foundation plate and rim joist. All that moisture is turning to mold. |
#3 |
Exterior Construction
Frosty wall
+1, lets see what the outside looks like.
Warm air + Cold concrete = frost and bulk moisture.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Frosty wall
I thought is might be easier to put the pictures as links instead of having a huge picture show up in the thread. So the link to the directory is here: http://www.usafloorhockey.org/assets/images/house/
pic1.jpg: The outside of the house on the corner where the frost was building up on the inside of the garage. Where the cement ends is the ceiling of the garage, the master bedroom is directly above. I checked the downspout and it does not appear to be frozen full of ice. The frost also did not start until a couple days after we got all the snow you see on the ground. The snow is not very deep against the house, maybe an inch. pic2.jpg: Just a close up of the last location. pic3.jpg: A view of the corner of the house from the other side of the fence. pic4.jpg: A close of of the wall, looks like some holes but they dont appear to be very deep. Thanks for all your help! |
#5 |
Frosty wall
QUOTE: Waffer102 - I thought is might be easier to put the pictures as links instead of having a huge picture show up in the thread.
************************************************** Good idea Waffer, thanks. Now if we could get admn to delete the original pic so we don't have to turn the page , so to speak, to finish reading each sentence. |
#6 |
Frosty wall
Basement/1st floor cantilevered area.
There is going to be a bunch of air flow from that area. You need to air seal that area ASAP and get it insulated. There are several thread in the insulation section about how to best accomplish this. Rigid foam to the exterior (courtesy of my friend GBR) is the best way to air seal and thermally uncouple the framing from the exterior. You need to stop the air movement and you are going to have to drop the ceiling or that exterior soffit to do it properly. Pull down a couple of those pieces of soffit and you will see what I am talking about.
| The Following User Says Thank You to Windows on Wash For This Useful Post: | Gary in WA (12-29-2012) |
#7 |
Moderator
Frosty wall
Here's the link, fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Add foamboard to the rim with canned foam, foam the rigid board joints, caulk the joist bottoms before the plywood soffit install, caulk afterward to stop all air. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Creating doorways/supporting wall issues | NWVintage | Remodeling | 2 | 12-19-2012 04:19 PM |
| Retaining wall work-- what approach? | emcelvaney | Landscaping & Lawn Care | 2 | 09-24-2012 08:49 PM |
| Retaining wall problem | FMS | Landscaping & Lawn Care | 6 | 07-04-2011 07:42 PM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
| Load Bearing Wall? | Traybae | Building & Construction | 1 | 11-05-2006 02:01 PM |
