Frost Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 04:01 PM   #1
Frost Wall
I recently excavated out a section of my basement so I could redo the drain tile and at the same time put in a walkout basement. My understanding is that I need to put in a frost wall 4' below grade. Is there anything more to the frost wall than brick and mortar?
My plan: pour in a footing, lay 8x16x8 brick with mortar up to the foundation (underneath).
Anything more?
allforfun is offline   Reply With Quote
Old 10-05-2010, 04:10 PM   #2
steveel's Avatar
Are you in an area where you're supposed to comply with code? If so, first thing I'd do is take my ideas to the building dept to ask what permits will be required.
You might find interesting reading among these google hits:
http://www.google.com/search?q=shall...ient=firefox-a
steveel is offline   Reply With Quote
Old 10-05-2010, 04:28 PM   #3
No - just trying to be safe and wise
Old 10-05-2010, 06:17 PM   #4
Rewards Points: 1,910
The frost protected shallow foundation that Steveel linked to might be a good option for you if your basement will be heated. You basically insulate the outside of your existing foundation so it won't freeze/heave.
Tags
concrete , foundation , frost wall
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
