Old 06-02-2009, 05:57 PM   #1
Frost on interior of vinyl windows
So my house was built in '97, original windows, 12 yrs old, have owned it for 3 yrs. Have developed bad frost on the interior corners of the double pane gas filled vinyl windows, wondering why? Seals gone, or insulation issues? Need to replace windows, or are there any other options? Vinyl siding on the exterior of home. Have used plastic sealer film past winters, on all, which does help, but temporarily solves it til next year. Heat is kept low year round, but we do get very cold winter months. Glass and walls surrounding windows is cold to the touch. Energy assement to be done in a couple weeks. Caradon, i think was the manufacturer. Opions please.
d.sharkey is offline   Reply With Quote
Old 06-02-2009, 06:55 PM   #2
Sounds like very cold air is getting in around the window. Probably an installation issue. You would remove the molding all around the window and add insulation into the cavities.
Ron
Old 06-02-2009, 07:09 PM   #3
Thanks, will have a look.
Old 06-30-2009, 12:02 PM   #4
Another common cause is that you may have excess humidity in your house. You may want to google condensation causes and cures. Newer homes are being built a lot tighter than homes that were built years ago which does not allow them to breath, hence trapping moisture within the home. Windows and doors are the coldest surfaces on your house. If you do have excess moisture present, once it comes in contact with the cold window surface, it will release this moisture in the form of condensation. On a double hung this usually collects at the lock rail and lift rail.
fenestrationman is offline   Reply With Quote
Old 06-30-2009, 12:25 PM   #5
Newbie Bill
Alberta is very dry in the winter so most of the time we have to add humidity to the home via a humidifier.
Having the humidifier up too high can lead to condensation and frost on the windows, even with the best windows and installation. Replacing the windows is the most common reaction to such a problem. But unless you have deep pockets, confirm your humidifer settings, pull off the trim and check for insulation.
So the question I have is how high do you set your humidifier?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-30-2009, 12:42 PM   #6
ccarlisle's Avatar
Often, and depending on the construction of the window itself, the little grey insulating strips of fabric within the channels that the window slides on becomes worn away, letting cold air come into the space between panes. This cools the aluminum just enough so that any moisture lurking around in there freezes.
You can buy replacement strips if you can figure out the profile, and it usually just threads in along the channel. I don't bother doing that myself, I brought a set of windows to my glass guy and his shop replaced them for $5 ea I think it was.
It's common and an easy fix.
ccarlisle is offline   Reply With Quote
Old 07-05-2009, 06:11 PM   #7
Pulled the cheap humidifer out when bought the house 3 yrs. ago, was a very shoty job and leaked. Was just a box with a drip/float system off the cold water intake for the hot water tank, cut into the out air off the furnace, haven't had one since.
Old 07-06-2009, 06:57 AM   #8
ccarlisle's Avatar
We've upgraded our house in so many different ways, here and there, that our humidifier on the oil furnace just isn't used anymore. We're 3 in the house + 2 dogs, and the humidity level (during the winter when it's most relevant) isn't a problem so I pulled the entire unit 6 years ago. Three showers per day+laundry+dishwasher+cooking gives us enough moisture to be confortable...having said that a cheap $8 humidistat is used regularly to disgnose problems like your windows.
And what about your window? any thought on what you might do? Hard now because it's summer...
Old 07-06-2009, 07:25 PM   #9
long island, NY
could it be glass failure in the window? (the seal went bad) just my uneducated guess....
diy'er on LI is offline   Reply With Quote
More On This Topic
Sewing the Sail Window
Sewing the Sail Window by Expert Village
In this clip, we're going to sew the window in. So, I'm here at the machine and we're going to start in the corner and what I'm going to do is sew with about a five millimeter zigzag stitch width and medium length zigzag stitch. And I'm trying to get the... Read More »
Prepping the Sail Window
Prepping the Sail Window by Expert Village
In this clip, we're going to show how to install a window in the sail. So, during the layout process, we put the marks on the panel where the window's going to go. And we're going to use a twenty gauge clear vinyl for the window. So, I'm just going to... Read More »
Hello my name is Jose Zuniga I'm representing expertvillage.com. Today we are adding protectant to the vinyl, to the dash board, anything that is plastic of the interior of the car. So what do we need for this project? Well we need a protecting wipes... Read More »
Hello! My name is Ron Sanders of Personal Touch Custom Auto World on behalf of Expert Village we will now explain the benefits of having window film in the vehicle. First and foremost is the privacy aspect. As you could on this vehicle you could not see... Read More »
Come February and March, we all get a little antsy to get out and dig in the dirt. Geraniums can be wintered over to give another season of bloom and more plants for the border. They can also keep you busy so you don't spend too much time with those... Read More »
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Replacing mylar windows with vinyl windows turkeybday Building & Construction 1 03-02-2009 07:03 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
